Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 11-01-2009, 09:25 AM   #1
Profile:  MARBLE FALLS , Texas
Help with holding tank leaks.
I have a 28 ft 1981 Excella motor home with a rear bath. Both my holding tanks have developed leaks in the bottom of the tanks.
Does anyone know where I might get replacement tanks?
What alternative way are there to fix the problem?
Bailey
bsutherland is offline   Reply With Quote
Old 11-01-2009, 09:48 AM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Bailey
Hello Bailey,
My approach would be to investigate the cause of the leaks first. It might be a fitting, or drain port.
Depending on the material used, sometimes repairs can be made to the tanks. Plastic can be welded with the right equipment, and fiberglass is also repairable. I imagine that Airstream could supply new tanks, if no other of the shelf tank fits.
A good source for generic tanks is Ronco Plastics, or Plastic Mart
Uwe
www.area63productions.com
Holding tank issue The Oats Waste Systems, Tanks & Totes 6 07-30-2008 09:25 AM
help with holding tank please milesmason Fresh Water Systems 3 09-12-2005 06:41 PM
How important to have a FW holding tank? live2dive Fresh Water Systems 6 09-28-2004 09:39 AM
need holding tank fredvv44 1959-69 Tradewind 2 07-12-2004 01:47 PM
holding tank ronnieb Waste Systems, Tanks & Totes 6 01-01-2004 07:39 PM
