Old 09-28-2010, 07:59 AM   #1
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Always searching for a place w/low Humidity , FT RVing, N & S, E & W, & in between
Help - Sticking Gate valve
This is a fairly new Thetford black water tank gate valve....I installed it 4 years ago....the old original one was leaking. The new one is now sticking when I try to open it to do a dump. It started with a "slight" stick and now I can barely get it open. I am fearful of pulling the rod and handle out of the gate slide....that's my worse case fear. It is a pain in the asset to replace the valve and very, very involved. I have tried putting 1/2 cup of dish soap in the tank after I empty it to see if that will lubricate the seals.....but that hasn't helped. I'm now thinking something like Auto Transmission Fluid!! Has anyone tried that? All recommendations will be appreciated. I definitely DO NOT want to replace that valve!! Bill
When you get a chance to "Dance" or "sit this one out".......I hope you DANCE!
lebolewis is offline   Reply With Quote
Old 09-28-2010, 08:15 AM   #2
Crusty's Avatar
1992 34' Excella
I put some vegetable cooking oil (a cup or two) into the black tank to keep the valve lubricated after every dump. If you're putting enough in, the valve will get easier to open (and especially) close.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 09-28-2010, 12:51 PM   #3
2010 27' FB Classic
N/A , Texas
Also, Thetford sells a lube that you put in the tank.
Campground near Algonquin's West Gate? Toronto_Guy On The Road... 4 08-28-2008 10:52 AM
New Waste Gate Valve for Black Tank? TylerFyre Waste Systems, Tanks & Totes 5 06-10-2008 02:18 PM
Water heater valve sticking. ldetsf LP Gas, Piping, Tanks & Regulators 2 11-02-2006 01:40 PM
Today gate valve, later check valve. GlenCoombe Classic Motorhomes 1 09-20-2005 12:02 PM
Sticking Dump Valve 74SovereignInt. Waste Systems, Tanks & Totes 12 10-05-2002 07:14 PM
