Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 03-08-2011, 12:43 PM   #1
cincinnati , Ohio
Help: Size of wastewater tank?!!!
Hello, is there anyone out there that has information on the standard size of a waste/black water tank for a 1967 airstream caravel? I don't have a owner's manual and the only other option is to take the belly pan off. I've tried to research the internet and found nothing. The fresh water tank looks to be 20-23 gallon tank. It is imperative that I get this info soon. I would greatly appreciate if anyone could shed some light on this area in question.
Best regards.
fallon is offline   Reply With Quote
Old 03-08-2011, 01:10 PM   #2
x
XXXX , XXXX
Fallon there is a simple way to find out. Start with an empty tank and add water one gallon at a time until full. Keep a count of the number of gallons added and there you have it, the capacity. Easy-peasy.
wasagachris is offline   Reply With Quote
Old 03-08-2011, 01:17 PM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Russellville , earth
8 I think, I will see what the manual for my 68 says
Rodney
Visit my photography and painting website
https://rooseveltfineart.com
Instagram is r.w.roosevelt
Boondocker is online now   Reply With Quote
Old 03-08-2011, 01:37 PM   #4
cojer's Avatar
1966 17' Caravel
salida , Colorado
i was going to say 8-10 if it's the original tank. wasagachris is right....start pouring!
cojer is offline   Reply With Quote
Old 03-08-2011, 01:57 PM   #5
kokopat's Avatar
Hendersonville, NC , North Carolina
My black tank is around 17 gallons and the fresh is 30 under the couch... '68 overlander
kokopat is offline   Reply With Quote
Old 03-08-2011, 02:08 PM   #6
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
The tank on an Overlander is going to be much bigger than a Caravel. I would say it's more apt to be in the 8-10 gallon range. Our '64 GT is 10...
Have you looked through some of the documents here for any clues? Your best bet is to use a gallon milk jug and your fingers...
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
'69 Globetrotter, Black tank for streetside bath dieselpup Waste Systems, Tanks & Totes 9 03-03-2011 06:50 AM
What size tank Brianv512 Waste Systems, Tanks & Totes 2 02-21-2011 10:09 PM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 04:10 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
