Old 07-17-2004, 08:45 AM   #43
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by 53flyingCloud
BTW, my end cap is "white plastic" on the dump..
It looks to be original..
ciao
53FC
Maybe it's another one of those CA vs OH things...or it was upgraded somewhere along the way...if only they could talk!
Shari
Old 07-17-2004, 12:37 PM   #44
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Originally Posted by JohnG
I know that most of us detest silicone, but in this area it is very easy to use to form a gasket. If you have the old gasket you can determine how thick it should be and then just cut a piece of wood to allow that thickness and width and also to use as a spreader for the silicone.
Thanks John, that's a great idea. Can anyone measure a gasket and tell me the thisckness?
Grant
DavidsonOverlander is offline   Reply With Quote
Old 07-17-2004, 03:10 PM   #45
InsideOut's Avatar
1956 22' Safari
Images: 108
There are detailed drawings in my photo gallery...
Term Cap
You can get the dimensions there...
Shari
Old 03-20-2006, 02:48 AM   #46
ventnor , isle of wight
Hi there please help i own a 1962 safari it also has the origonal sewer fittings what i want to find is how do I connect a 3 inch flexie hose to this fitting
i have tried varios adapters but no luch
Frazer
London
UK
frazer45 is offline   Reply With Quote
Old 03-20-2006, 06:08 AM   #47
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Frazer
London
UK
Frazer, unfortunately you have the same trouble that most of us Vintage People have with those valves, and that is nothing will fit it. The valve is a Valterra, but neither it, nor the caps, have been made for many years (decades). I was able to remove the valve from my coach, and replace it with a new Valterra 2" slide valve, and a collage of PVC pieces to fabricate something that would fit a 3" hose.
I know it isn't what you would like to hear, but that will likely be the only way to make your sewer hookup "fit".
67 Tradewind window part needed JimC Windows & Screens 9 11-27-2009 10:27 AM
Part needed to hang curtains Herm and Debby Upholstery, Blinds, Walls & Interior Finishes 6 07-22-2003 05:53 AM
