Old 10-23-2002, 10:38 PM   #29
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Sorry Oscar, somehow your latest (10/10) response slipped by me.
Since we've been back from the balloon rally, we moved our office & I have been up to my eyeballs in trying to play catch up!
What two views do you need ~ side & front, right? What format .jpg or what? Do you need any dimensions or anything else? Sorry if my lack of response has held you up...I appreciate your effort to help out with this...
$20-30 sounds fine with me...
Shari
Old 10-23-2002, 10:44 PM   #30
InsideOut's Avatar
1956 22' Safari
Images: 108
64GT ~
Could you provide photos of your termination cap for Oscar also? I think the more we have the better...
Shari
Old 10-23-2002, 11:04 PM   #31
Silver Bullet's Avatar
Hi Shari,
I know how it goes, been busy myself, infact the AS forums have been a social Godsend . The only views I was looking for were the side and bottom veiws. Dimensions won't be a problem since the ones you posted match mine. Post the pic's on forum like last time or E 'em to me. I just want to make sure that it is like mine without the handle or if there is a bit of a difference between the two. Just want to get as close to "stock" as possible. Don't worry about response time, patterns are not shelf items, I'm still working (spare time) on the one I need! Oscar
Silver Bullet is offline   Reply With Quote
Old 03-07-2004, 02:33 PM   #32
RichardT's Avatar
here is a pictur of another
RichardT is offline   Reply With Quote
Old 03-07-2004, 05:32 PM   #33
InsideOut's Avatar
1956 22' Safari
Images: 108
Smile
Thanks Richard!
I did purchase one several months ago...actually two! I thought posted pictures here, but it must have been around the time of the forum crash, because it's not here any longer...strange.
Here's a picture of the ones I got:
The handled one on the left I sent to SilverBullet, the one on the right kept.
However, the one you are offering is different from both of these so I may decide to bid anyways...we'll see.
Shari
Old 07-16-2004, 05:59 PM   #34
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
I need one too!
It looks like I'm on the same quest now with my '64 Bambi II! Here is what my fitting looks like...
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 07-16-2004, 06:04 PM   #35
InsideOut's Avatar
1956 22' Safari
Images: 108
Hmmm...looks a little different than ours, but the same cap may work. Have you tried the modern term caps? If so & you're still looking...good luck, patience is a virtue! They're out there...just gotta be ready to buy it when you find it!
Shari
Old 07-16-2004, 06:13 PM   #36
That handle is for the KT lock that was used on the inside.
That lock was used from 1970 to 1977 in the Airstream trailers and the Argosy trailers.
Old 07-16-2004, 06:17 PM   #37
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I might have a set of these. I have the dump hose elbow, as well as the tarmination cap with a hose tread bib in the middle.
There is a fair amount of corrosion on the cap, but the dump hose elbow seems to be in good shape. I cantqake some pictures on Monday, when I get back to the office.
Uwe
www.area63productions.com
Old 07-16-2004, 08:36 PM   #38
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I'm lucky enough to have the cap and the elbow, but I need gaskets for them. Anyone know where to get a gasket, or what kind of material to make one from?
Grant
64 Overlander
DavidsonOverlander is offline   Reply With Quote
Old 07-16-2004, 10:18 PM   #39
JohnG's Avatar
I know that most of us detest silicone, but in this area it is very easy to use to form a gasket. If you have the old gasket you can determine how thick it should be and then just cut a piece of wood to allow that thickness and width and also to use as a spreader for the silicone.
I'll post a diagram of what I mean for the stick spreader..............
Place a thick bead of silicone around the area to form the gasket then just use the stick that you made as a spreader to form the gasket all the way around, and then let it dry and you have your gasket.
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 07-16-2004, 11:45 PM   #40
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Question~
Shari~
In looking at your picture:
Is that green grass I see in your storage compartment?
Did you ever find the frying pan??
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 07-17-2004, 12:06 AM   #41
InsideOut's Avatar
1956 22' Safari
Images: 108
Sort of...
Originally Posted by 53FlyingCloud
Shari~
ciao
53FC
The slide hatch at the bottom, where the sewer hose feeds out was open & Maxwell was parked in the yard when that picture was taken. Whatcha think, I grow grass in my trunk? I don't think so~
I sold the frying pan cap to Silver Bullet. We didn't need both...
Shari
Old 07-17-2004, 12:48 AM   #42
1984 29' Sovereign
Savannah , Missouri
Actually...
Shari
Shari,
Mine looks like that now, with the belly pan removed.lol
Still working on removing the pan under the tank.
I got to tell you, those retainer bolts are hard to remove~
(If they would just stop moving around on me...lol)
The new pan, unlike the old one, will be designed to drain water accumulation.
Plus, I plan to make it easier for removal in case there's any future work in that area.
BTW, my end cap is "white plastic" on the dump..
It looks to be original..
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
67 Tradewind window part needed JimC Windows & Screens 9 11-27-2009 10:27 AM
Part needed to hang curtains Herm and Debby Upholstery, Blinds, Walls & Interior Finishes 6 07-22-2003 05:53 AM
