Old 02-27-2010, 09:18 AM   #1
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Exclamation HELP! New/used Bambi has crap in the craper!
I just brought home my bambi and everything seemed good winterized etc but I was playing with the moniter and the black tank now shows full. It was showing empty last week so I got out my flashlight and looked in the toilet and there is a large pile in there! Anyway to flush just the black water tank without de winterizing it? I dont want to have any problems down there. It looks like there is antifreeze in there now but I've been running the heater so now the is a faint smell when I looked in the toilet. Please help! ;(
blmitch5 is offline   Reply With Quote
Old 02-27-2010, 09:23 AM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
You could pour buckets of hot water (from your house) down the toilet without dewinterizing. Let the gate go (if you have a place to dump what comes out) & repeat it a few times.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 02-27-2010, 09:26 AM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I would suggest the buckets of hot water also. In addition, you may have to do it several times, I would also drive the trailer around with the hot water in the tank to help dissolve and shake the contents up before dumping.
Bill
Just my personal opinion
Old 02-27-2010, 09:29 AM   #4
blmitch5's Avatar
Olathe , Kansas
Thanks will do!
Old 02-27-2010, 09:58 AM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Sounds like the previous owner either didn't practice dumping the tank full, or never was instructed that you don't leave the black water drain valve open when connected to a full hookup site.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 02-27-2010, 11:03 AM   #6
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
garden hose
If you have access to a garden hose you can always attach a wand to that and blast the @#$%^ off the bottom, with the sewer hose connected if you have a way to dump at home. Good luck!
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 02-27-2010, 11:04 AM   #7
blmitch5's Avatar
Olathe , Kansas
Flushed it out with hot water. Not too much in there but flushed it out unitl clean water flowed through a couple times. The tank moniter still shows full. It looks compleatly empty and I put @ cup of antifreeze in the toilet. Shoud I re calibrate my sensors? Or maybe it is a faulty sensor? Any idea how I can check? As for not dumping correctly, could be the case. They only camped in her 3 times and when I went to fire up the furnace the instructions were still inside the heater. So far everything looks good. Dead maggots are gone too! A perfect way to spend a Saturday. Thanks again for all of the help, maybe someday I will learn enough to return the favor for the next newbe!
Old 02-27-2010, 11:26 AM   #8
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Sometimes that will correct itself after cleaning as everything slips off the sensor. The level monitors are notorious for reading full all the time, though. Especially the black tank. Thetford makes a product called Level Gauge Cleaner to address the problem. You should be able to find it or something similar at a RV place.
Instructions are:
Usage:
1. For cleaning Holding Tank Level Sensors: Choose a warm day - at least 75F. Fill 40-gallon tank with water. Add bottle. Mix by driving vehicle. Let sit 24 hours. Drive vehicle again to loosen deposits. Empty and rinse holding tank.
2. Alternative Use Method: Fill tank full with water. Add bottle and deodorant to tank. Use holding tank as usual.
And another paragraph telling you to use often, etc...
When it's all said and done, I just look down the toilet when I suspect it is getting full and pretty much ignore the monitor.
Vaughan
Old 02-27-2010, 11:29 AM   #9
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
It's probably got "crud" on the sensor, a very common problem.
One less expensive fix is to wait until some warmer weather, then dump a couple of bags of ice into the tank along with some water, and take a nice, bumpy, curvy drive. (Dump, rinse, and repeat, as needed, just like the shampoo manufacturers suggest.)
But the comments from others are right on target: Never leave the black tank open, but rather dump only when it's closer to full. And at the conclusion of a trip, give it a good rinsing.
Lynn
WBCCI 21043
Old 02-28-2010, 08:58 AM   #10
blmitch5's Avatar
Olathe , Kansas
Thanks for the advice. I'll look forward to spring! I wish it would hurry up and get here! I have the AS bug BAD!
Old 02-28-2010, 12:02 PM   #11
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Keep reading the forums and before you know it you will be an expert in one or more areas of Airstreams and will be dishing out advise left and right.
Family of Disney Fanatics
WBCCI# 4821
Old 02-28-2010, 01:19 PM   #12
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
ya you got piles, very hard one.the only cure is soapy water and warm weather.
wbcci ,#3510 NEU & 4cu http://fire1.smugmug.com
firedog is offline   Reply With Quote
Old 02-28-2010, 01:47 PM   #13
LisaP's Avatar
2008 25' Safari SS SE
Colleyville , Texas
We had the same problem. Empty black water tank but sensor read full. There is a phone jack type connection under your trailer near the clean out. This gets road dirt and sometimes needs to be cleaned off. My hubby just removed the cable from the phone jack and rinsed it off with a cup of water. Plugged it back in and it fixed the problem. Hope this helps. The sensor is right at the base of the black tank.
LisaP is offline   Reply With Quote
Old 02-28-2010, 02:55 PM   #14
c177tx's Avatar
2008 19' Bambi
Images: 20
I second the phone line fix, same problem and same fix for my 08 19' Bambi
c177tx is offline   Reply With Quote
OH CRAP(er) Boondocker Sinks, Showers & Toilets 29 02-28-2010 08:22 PM
Walmart Crap Getting Crappier? Foiled Again Off Topic Forum 56 01-12-2010 06:18 PM
NWS : Collier Crap Shoot Rally Janet H Forum Rallies & Meet Ups 23 10-28-2008 08:11 PM
Crap in the gas tank 345 OttawaValleyGuy Classic Motorhomes 3 08-31-2008 12:11 PM
Gummy crap between thermopane windows Robin Stone Windows & Screens 2 12-19-2007 05:44 PM
