Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 07-27-2014, 11:41 AM   #1
shiva-shantz's Avatar
1978 Argosy 24
Otisville , Michigan
HELP! I am in over my head & need info about grey tank (and much more)
I am new to trailer upkeep and I have a 1977 Argosy 26ft. I am having a lot of trouble getting to know my trailer and I believe I am driving my camper around with a full tank of grey water. The reason I believe this is the case is I can see water in my shower drain. I have read my manual about draining the tank, but when I pull the valve to empty the grey water nothing happens. I am a single mother, and it is daunting enough to be driving a large trailer with my children around, but if I am driving around with all that extra weight, it is a bit more stressful. We have a second trip camping in a few days and would love to resolve this issue. (I don't plan to use the shower,sink, or toilet at this time because I have no idea how to maintain the system) I am having some other questions too but I will try to search topics before asking in a new thread. Please help, Thank You
shiva-shantz is offline   Reply With Quote
Old 07-27-2014, 12:03 PM   #2
Air-Texas's Avatar
2004 34' Classic S/O
Stafford , Virginia
There should always be water in the drains, it keeps the sewer smells out of your trailer.
Your drains in your house work the same way, but because they are deeper, you do not see the water.
Mike, Miho &
S/OS#069
TAC # TX-33
WBCCI #5702
"Eva" 2004 Classic Limited 34' S/O
"Wall-E" 2012 Ford F250 King Ranch
Air-Texas is offline   Reply With Quote
Old 07-27-2014, 12:18 PM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Hi. Do you know if your trailer has black and great tanks? The black would be for the toilet and the great for shower and sinks. You may be pulling one handle (for black) and need to pull the other (or grey).
Also, do you have tank monitors and if so, what do they say? Not that they're very reliable - just trying to know more about your situation.
Old 07-27-2014, 01:00 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
I have sent you a private message with my phone number. Call me
2004 Excursion 4x4
Old 07-27-2014, 01:37 PM   #5
1978 Argosy 24
Thanks! I will give you a ring Howie. And I do have 2 tanks, which I have tried to pull both levers and nothing comes out. I am curious about the idea that you are supposed to see water in the drain.
Old 07-27-2014, 01:38 PM   #6
1978 Argosy 24
And I don't believe I have any monitors either....
Old 07-27-2014, 03:04 PM   #7
Air-Texas's Avatar
Stafford , Virginia
I had the same trailer, and could see water in my tub drain.
The handles for the tanks were in the back bumper.
Mike, Miho &
S/OS#069
TAC # TX-33
WBCCI #5702
Old 07-28-2014, 06:23 AM   #8
1978 Argosy 24
Thanks to Howie, I now know that I do NOT have a full tank of grey water. I also do not have one VERY large mouse (maybe a small rat) taking up residence in the tank anymore! I will be sure to put the cap back on so he doesn't come back again!
Old 07-28-2014, 07:00 AM   #9
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
It is normal to see water in the p-traps.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-28-2014, 07:45 AM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
When it is parked and in use; yes.
When you are driving quite often the water will slosh or be sucked out of the traps.
Aaron
WBCCI #XXXX AIR #2495
Old 07-28-2014, 08:23 AM   #11
dznf0g's Avatar
Oswego , Illinois
Usually, I'll only see water in the shower drain, as it is a low profile p-trap. And of course in the toilet. The sink traps ar very much like the house and you can't see the water in them.
-Rich-
Old 07-28-2014, 08:51 AM   #12
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
If there is NO water in your shower or sinks, you have a problem. Water is good as stated before by others, the water prevents the gases from the tank entering your trailer. Nasty!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 07-28-2014, 12:39 PM   #13
m.hony's Avatar
2013 30' Classic
Aaron
Yep.
I always forget to step on the toilet pedal.
Water comes from somewhere even when I step on the pedal- maybe it was already in the lines or in the innards of the bowl?
Sometimes the water sloshes out-
There is always a little water in the dump valves, even when drain them completely-
TAC #MS-10
Airforums #70955
Over head storage bins rebuild and LED lights! cmadmaxman Classic Motorhomes 7 09-08-2016 05:04 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
See more. Do more. Live more...? Mike91208 Airstream Lifestyle 2 01-26-2012 06:56 AM
Over my head and sinking further. Deano69LY General Repair Forum 2 11-08-2005 05:25 PM
One more grey tank ?? escapeez Waste Systems, Tanks & Totes 2 09-09-2002 10:55 PM
