Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 05-27-2002, 12:45 PM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
waste tanks...
did I read somewhere that older airstreams don't have both a gray-water and black-water tank? What year was it that they added a separate grey-water tank? any big disadvantage to only having one?
Old 05-27-2002, 01:35 PM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
During the timeframes that these one tank A/S were built it was quite acceptable to dump the water from sinks and showers onto the ground. Now we have zoning, EPA, and all the other comforts that modern society brings about, the practice in many places is no longer allowed.....thus the need for two tanks...or at least the need to buy a "blue external tank" to store the gray water into.
You really don't want gray water into your black water tank due to the potential for backflow into your sink or shower once the tank fills.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 05-27-2002, 01:51 PM   #3
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Grey water tanks began in 1973.
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 05-27-2002, 02:33 PM   #4
Administrator
Andy R's Avatar
1961 16' Bambi
Dallas , Texas
Images: 13
Re-plumbing, should I add a grey tank?
I have a 1961 Bambi, I currently have it gutted and will re-plumb the entire unit. Should I add a grey water tank? If so, where should I look to get one?
I have a 25 gallon white water tank, would it be ok to have a smaller grey tank? I don't think I can find the room for another 25 gallon tank.
AIR # 2 - 1961 Bambi - Jeep Cherokee
Campground Reviews: Submit and review campgrounds around the US
Andy R is offline   Reply With Quote
Old 05-27-2002, 02:51 PM   #5
BobbyW's Avatar
Houston , Texas
This is a classic example of something not running uphill.
If you look at the waste system, the Black water tank is sitting high in the waste system loop, under the step up in the bath area. A grey tank will have to be low in the waste loop so that the shower will drain from the P-trap and into the tank and not back up.
One novel solution that I have seen was built from 6-inch PVC pipe and U-fittings or 90deg ells close nippled together. It was connected in a close fitting series of loops in the space between the belly pan and the floor and the waste line was run to it. Still would need to be lower than the shower p-trap or the full capacity would not be utilized. Not sure what this would do to weight distribution though if pulled full of water. It would have to be supported from the frame as water weighs 6 pound per gallon.
I would just get a 25 gallon wheeled blue tank and stow it in the bath when under way and store it under the trailer when parked or hooked up to shore. A lot cheaper and no labor involved.
-BobbyWright
Edited for the usual typo's, in a hurry, have 40 people over for a Memorial day BBQ (Honor our Fallen Freedom Fighters)
BobbyW
AIR# 123
Old 05-27-2002, 03:10 PM   #6
jcanavera's Avatar
Fenton , Missouri
Images: 143
Re: Re-plumbing, should I add a grey tank?
Andy,
You can probably get away with adding a tank if you are going to empty it before travel. Your Bambi wasn't designed for the weight load that an additional tank would add when traveling.
Personally I'd buy a portable blue tank. It's probably not worth the effort to try to add an onboard tank....especially if its small. At that point you would now be in a situation where you have a small full gray water tank. You will find that with the rolling tanks available, it's much easier to roll them to the dump station to empty than to deal with a small full gray water tank.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 05-27-2002, 09:18 PM   #7
Administrator
Andy R's Avatar
1961 16' Bambi
Dallas , Texas
Images: 13
Talking My reasoning
The way I see it, the trailer will not be adding much extra weight, only the actual weight of the grey tank. The water will simply be re-distributed.
My plan is to use the trailer most for short trips. Some may be down to the local river to fly fish or as base camp and lunch spot on a day of hiking. On those days I certainly want to be able to use the sink. So maybe putting a small grey tank (5-10 gallons) for sink water would suffice? When I go on longer trips and want to use the shower, then a portable blue tank could be used (if I was in an area that did not allow direct discard or the grey water).
Questions? Comments? Your input will keep me from having to make a mistake and learn the hard way! THANKS.
Old 05-27-2002, 09:39 PM   #8
jcanavera's Avatar
Fenton , Missouri
Images: 143
Re: My reasoning
Andy,
You're right if 10 gallons out of your fresh water goes into the gray. In that instance it really then only becomes an issue of where you place the new tank. If it is in the same area of the fresh water tank then you haven't done much to affect the trailer. But if you place the tank in a different area, you technically are making an alteration that could affect handling. Also if you don't dump the new gray water tank and take on more fresh water, you then increase the load.....not an issue here if you can keep the trailer at or below the GVWR.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 06-03-2002, 04:30 AM   #9
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
another question on the subject....
The trailer I just looked at only has a single waste tank (73 safari), but the owner showed me how it hooks up to the sewer...there was only 1 connection under the trailer. So I can only assume that all the wastewater goes into the black water tank. I think this would be rather limiting at some of the places that I'd like to camp....(no sewer hookups...just a dump station). I guess these folks only like to go to places that have full sewer hookups, so its not a problem for them. But how much of a horror-show would it be to separate the system out so I could use one of those portable blue things?
Old 06-03-2002, 05:01 AM   #10
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
Send a message via AIM to thenewkid64 Send a message via Yahoo to thenewkid64
The grey pipes should just connect into the sewer pipe. The grey water would just be dumped on the ground in 1973. If I am right (someonone who KNOWS pipe up!) then both systems are seperate. You could attach a tote-tank to the sewer fittting and collect the grey water without modifying your trailer.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-04-2002, 09:20 AM   #11
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
But.....
I'm thinking that they must have re-plumbed this so that the grey water goes into the black-water tank. They only hook up a single slinky to the sewer, and there doesn't seem to be any other connection under the trailer for grey-water. The owner's told me that it all comes out that one pipe.
I did see a hole of some sort in the aft end of the trailer that I'm assuming was the original waste port for the grey water. It is located in the rear-curbside corner of the trailer, and is about 2 inches in diameter. doesn't look like anything has come out of there for a long time. I asked the owner what it was, and he didn't even know it was there!
What I'm wondering is how difficult will it be to re-configure so I can have a separate grey tank. (portable external, or otherwise). It doesn't look like its very easy to access the plumbing.....
Old 06-04-2002, 11:31 AM   #12
Just a member
1978 28' Argosy 28
Lutz , Florida
Images: 21
Chuck,
after re-reading your question and my reply I khink I may not have given you a full explanation.
All waste water will come out of the main outlet that the prior owners have been hooking up to a sewer fitting. This is the standard for ALL RV's even today. In the case of a trailer with no grey tank the grey water will just flow into the main outlet and flow down the sewer hose. When camping where you have no sewer but can drain grey water on the ground, most RV'ers connect an old piece of GREEN Garden hose (3-4 feet) to the small hose fitting on the sewer cap. If the cap you have is without fitting, you can get one at Camping World. This hose is then typically tossed under the trailer to allow the grey water to drain on the ground without passers by walking thru it. This is the way everyone at the international rallies have to drain grey water.
It you were to hook up a tote tank to the main serwer outlet then you could collect this grey water and "tote" it to an approiate dump location.
The 2 inch "Hole" you mentioned may be a prior owner modification to store the sewer drain hose.
You are correct in your statement that the plumbing would be difficult to get to, I would just get the tote tank if I were you.
Brett G
Old 06-04-2002, 01:48 PM   #13
CPRcubed's Avatar
My 1971 also does not have a grey water tank. The grey water system connects to the sewer line just downstream of the dump valve for the black tank. In my opinion, it is easier to use a 15 gallon blue rolling tank for the grey water. Besides, at the rate my wife and kids use the water, I have to empty the 15 gallon tank every day (and I'm not going to pull up camp for that with a fixed tank!). Cheers!
1971 25' Airstream Trailer, 1994 F350 CC DRW 7.3L PSD Life is Good in Bear Valley Springs!
CPRcubed is offline   Reply With Quote
Old 06-04-2002, 01:54 PM   #14
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Ok, I think I've got it now....
You'll have to excuse my ignorance...never owned any kind of camper before....
So is it ok to just dump grey water onto the ground like that? I suppose it must depend on your location....
So the system must look something like this:
Old 06-04-2002, 05:49 PM   #15
Just a member
1978 28' Argosy 28
Lutz , Florida
Images: 21
Your drawing is an accurate depiction of the waste water flow. With regard to the grey water on the ground, diffrent states have diffrent rulings on the issue. You will need check with the managers of the campgrounds or park that you check in to. I know that it is allowed in some, but double check, because it could lead to a fine if it is illegal.
Brett G
Old 08-01-2005, 09:10 PM   #16
fastrob's Avatar
1976 25' Tradewind
. , Maine to Arizona
Removable Blueboy Greywater Tank
Has anyone come up with a way to have a cassette greywater tank?
The tank should hold about 25 gals and be removable to go to the dumping station.
Maybe I'm dreaming but why not use (1) greywater tank 100% of the time instead of having two, one fixed and one with wheels.
Are the blueboys used for black water shuttles too?
fastrob is offline   Reply With Quote
Old 08-01-2005, 10:09 PM   #17
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Turd Tote...
Some do...we don't.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 08-02-2005, 08:42 AM   #18
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
wow, old thread, from when I was a newbie....
but since then, I have learned that there are occasions where you want to be able to dump grey water onto the ground. should the need arise, it is nice to have that flexibility. its never ok to dump black water on the ground. but if its kept isolated in its own seperate tank, you can go a long while in between dump station visits. Grey water is usually more of a problem....and even if you have a seperate tank for it, its not an unpleasant task to drop it into a blue-boy and shuttle it over to a dump. (oh, and a 25 gallon "casette" would be too heavy to lift in and out of the trailer...but not a problem if you have a large, 4-wheeler that you can tow to the dumpstation.)
You don't want to do that w/ the black tank. trust me. You "can" do it, in a pinch, but having done it myself, and having just recently been in close proximity to someone else that was doing it, it wasn't pretty. but it is do-able. (hey, if you have to, you have to.).
I think manufacturers have asked themselves the same question, though: "why not just use one tank?". and they haven't been able to arrive at the same conclusion that I have. So they put in one single large tank in some newer models. I can only assume that they're thinking that the end-users will never need to or want to dump anywhere but a sanitary facility, and therefore, don't need any sort of flexibility. Personally, I wouldn't buy a new camper with a single tank. If nothing else, I'll always be able to let grey-water drain onto the ground on my own property.
just one tip, should you ever decide to shuttle black-water using a blue-boy: USE A SLINKY.
this joker that was ahead of me at the dumpstation last weekend...he ran into a problem, couldn't get pumped out because it was the weekend, and had to empty his black tank. so he used the blue boy. (fine, if you must). Problem was, he didnt' use a slinky when he was dumping the blue-boy into the 4" hole at the dump station. he took the cover off the tank, lifted up the other end, and a GUSHER of liquified poop spewed all over the F*$(*#n place, followed by an odiferous cloud which proceeded to envelope everyone within a hundred feet of him. (dumb-ass!! ). of course, it also left god-knows-what all over the place for the next guy in line. (me).
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 08-02-2005, 09:53 AM   #19
InsideOut's Avatar
1956 22' Safari
Images: 108
At International...there were a couple of outhouses set up near the vintage parking area for convienence due to smaller tanks. There was also a dump location a bit further away...but some lazy idiot choose to empty their Blue Boy full of black water into one of the outhouses! Same thing, obviously no slinky was used and 'it' gushed...'stuff' E V E R Y W H E R E ! All I hope is that they got covered in 'splashback' and it ruined their day! I pitied the poor folks that got to clean up that mess up...
BTW the sanitation folks at International were the BEST! They get extra kudos from me ~ they were a church group raising moneies for their local building project...talk about a service project!
Shari
Old 08-10-2005, 02:02 PM   #20
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
tanks for the advice...
... ho ho... that's bad.... anyway, i'm at the point where i need to decide about the tank set-up on my trailer as well. i am putting in an oversized fresh water tank under the floor of our 18 footer (32 gallons). it hangs down 4 inches, so i hope it's not too disruptive to the look from the side. it'll all be covered by a stainless steel support pan... but back to my point. at the rear, i have a 27 gallon tank, originally intended for grey water, and the toilet in the back would theoretically dump into one of those above floor black tanks.
i had thought about ditching the black tank and having it all dump into the 27, but upon thinking it through, i think i've decided to keep 3 tanks, and have a secondary pump that would pump the grey water into the black tank to help wash out the nasties, with a macerator pump hooked to the bottom of the black to make dumping a snap. i still need to draw this out so i don't forget anything.
am i over-engineering this?
8576 • • • • • • • •
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Using grey water for flushing....? Sneakinup Waste Systems, Tanks & Totes 9 11-04-2003 04:52 PM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
Waste Water Tanks jalewis Our Community 2 07-31-2003 08:01 PM
grey water plumbing vent Cruiser Waste Systems, Tanks & Totes 6 07-14-2003 02:03 PM
Retrofit Grey water tanks smily Waste Systems, Tanks & Totes 10 02-01-2003 12:17 AM
