Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 05-10-2003, 06:47 PM   #1
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
grey water valve repair
hello gang,
just spent a pleasant saturday afternoon fixing my grey water leak.
i was able to repair it with parts found locally. $16.38 total.
first thing i did was get some room to work.
Name:	on the skids.jpg
Old 05-10-2003, 06:49 PM   #2
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
tin snips
then i cut a hole and found the problem.
Old 05-10-2003, 06:50 PM   #3
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
went on a parts run...
and got this:
Name:	new parts.jpg
Old 05-10-2003, 06:53 PM   #4
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
the culprit
here is the remainder if the flange broke off in the tank.
Old 05-10-2003, 06:55 PM   #5
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
so i made a new one
with a flange and a section of pipe...
it is sealed into the tank with our friend vulkem.
Name:	greased up and ready to go.jpg
Old 05-10-2003, 06:58 PM   #6
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
then installed it
the hose clamp (heavy duty aircraft type) squeezes the connection tight.
note the vulkem oozing out.
Name:	vulkem and aircraft clamp.jpg
Old 05-10-2003, 07:02 PM   #7
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
then i closed up the hole
with some more goo and pop rivets.
after filling the tank and checking for leaks, there were none!
Old 05-10-2003, 07:05 PM   #8
Profile:
Are you saying there is no other easy way to reach that valve without cutting a hole?
1992 and a leak?? you are starting to scare us.
Mike just mentioned that it's a good thing your trailer is not one of those I have heard called "vintage" , they would throw you out of the forum for doing a repair that looks so efficient and practical
femuse is offline   Reply With Quote
Old 05-10-2003, 07:06 PM   #9
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
ducks wtf?
really wasn't that bad of a project, about 3 hours including the parts run.
while i was under the trailer i kept hearing quacking...i thought i was going nuts!
after i crawled out from the trailer the last time i noticed these two less than ten feet away!
john
Old 05-10-2003, 07:09 PM   #10
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
by the book!
femuses,
just followed the instructions in my manual.
it sez: "don't skimp on the size of hole you cut, bigger is better!"
john
miller time!!
Old 05-10-2003, 07:16 PM   #11
Profile:
Nice looking job.
You are lucky to have an acurate manual, ours is pretty much useless.
How much do you think that Airstream would charge for it ? [no need to answer]
I'm not sure how good are those ducks under the trailer. Eating bugs? At least our rabbits are trying to remove some of the grass that keeps on growing there.
Old 05-10-2003, 07:23 PM   #12
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
ducks
my golden retrievers found those ducks to be quite a lot of fun!
at least they are good for something, the ducks that is.
woof woof quack quack woof woof!
john
Old 05-11-2003, 09:20 AM   #13
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
"woof woof quack quack woof woof!"
You crack me up.
On a side note, where did you get that manual? Mine is pretty shoddy too. I have the schematics, but no really step by step like my car shop books.
My valve is on the outside, so I'm not too worried about having to dig in, but it would be nice to have the Airstream "shop" books.
Eric
Old 05-11-2003, 09:45 AM   #14
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
just the regular book
that came with my trailer. is all i have.
perhaps '92 was a rewrite year for the manual.
there are still images from the early 70's, judging by the types of cars pictured.
but the referances to the plumbing and electrics have been accurate.
i don't know if "shop manuals" are available for later model trailer.
my buddy got a set from helen davis for his '74 excella. it goes into great detail. more than the "regular manual".
john
fresh water tank plug and valve repair john hd Fresh Water Systems 38 08-06-2009 10:35 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 09:45 AM
86 345 MH Grey Water Valve Extension Jim Tyrney General Motorhome Topics 1 11-17-2003 09:50 PM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 08:59 PM
City Water Valve Assmbly Question sladew Fresh Water Systems 3 08-11-2003 11:38 PM
