Old 08-15-2010, 12:55 AM   #29
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Although, if you don't want to put your hand through a sharp edged hole into a black water tank to feel around, nobody would blame you...
TX-16
Dave Park is offline   Reply With Quote
Old 08-15-2010, 01:00 AM   #30
altnbndr's Avatar
1967 17' Caravel
1968 22' Safari
Sacramento , California
Images: 11
I have been a union sheet metal worker (local # 162) for over 20years. I cut metal on a daily basis, I would recommend that you make these cuts with Midwest offset snips available at Sears. The offset snips allow for the metal to feed out of the cut (curl).You will need reds and greens. Red handled snips are for making left cuts ,Greens are for making right cuts. hope this helps.
altnbndr is offline   Reply With Quote
Old 09-01-2010, 01:54 PM   #31
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
The cutting of the hole is pretty straightforward. Is there any guideline for locating the hole so it will provide best access to replace the valves ???? What is recommended to close up the open area after the repair is done ???? I guess the "dump" connection will give a basic starting point but so as not to cut any more than necessary it would be nice to have a general guide.
Are both valves the same ??? Is there a repair that will take care of a valve that is simply seeping or is it best to replace ????
Thanks all,
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 09-21-2010, 06:51 PM   #32
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Thanks all,
I was able to look into the drain valve area and the thetford valve part number for my AS was stamped right on the valve. I assume both valves are the same but will check with Inland when I place the order.
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
tvanwave is offline   Reply With Quote
Old 09-27-2010, 04:32 PM   #33
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Inland thinks both of my valves are the same. Ordered two and will find out next weekend!
Air Cid
Reese WD Hitch
Old 12-21-2010, 04:30 PM   #34
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Time came to fix my own leaking grey water valve. Taking John HD's lead, I decided to make a real access panel so I could get to the dump valve area without a lot of fuss. To make the access panel, I first had to let the tank holding pan down so I could make my cuts. To do this, I remove the pan mounting bolts on the driver side, the front and on the rear of the pan. This let the pan drape down so I could get at it with my jig saw. I chose to cut out a section of the holding tank pan and use that cut out section as an access panel. I used a 1" aluminum channel to straddle the cut seam so I could reattache the access panel. In this pic, the grey valve has been removed.
I pop riveted the aluminum channel to the tank pan body:
Here's a pic with the grey valve back in place. Turned out, the OEM mounting flange which connects the holding tank to the valve fell apart from age. I think it was made of styrene plastic. The replacement is PVC
Here's the access panel reinstalled and everything trimmed and ready to go. The access panel can now be removed by taking out about 17 screws and 2 bolts, exposing all the valve assemblies.
Easy to do repairs there from now on!
So Long!
Bob Thompson is offline   Reply With Quote
fresh water tank plug and valve repair john hd Fresh Water Systems 40 06-01-2010 01:45 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
'86 345 MH Grey Water Valve Extension Jim Tyrney General Motorhome Topics 1 11-17-2003 08:50 PM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
City Water Valve Assmbly Question sladew Fresh Water Systems 3 08-11-2003 10:38 PM
