01-08-2008, 11:56 AM
1975 Argosy 24
Collierville
, Tennessee
Grey water tank nothing drains
When I pull the valve out for my grey water tank nothing drains out and I would think after using the sinks for a week at the canopener it would have backed into sinks w/ tank full but this did not happen. Is it possible that the PO combined the lines so that the grey water tank drains when the black water tank valve is opened and that the valve for grey water no longer does anything? I plan on running a lot of water into the sink and see if the tank gets full and backs into the sinks or shower to see what is going on. I would appreciate any help. I have a 75 Argosy24.
Different strokes for different folks!
I never learned from a man who agreed with me.
Heinlein
01-08-2008, 12:02 PM
Retired.
, At Large
Your Argosy should have a 10 gallon grey tank, unless it has been retrofitted with a larger one. You can open the valves and run water into the drains to see if anything comes out, you don't need to max it out, unless you want to verify tank capacity. For that, after you make sure everything is working, just start dumping full gallon jugs of water into the tub with the valve closed, and stop when it back up, that would be your capacity.
01-08-2008, 01:12 PM
St. Cloud
An OEM Argosy black water tank is above the floor. Lack of cabinetry access to this area would suggest you still have the OEM setup. I don't think they could practically combine the two tanks. Your feet are directly above the gray water tank when you're standing inside the bathroom door.
Black water pull is forward of the rear streetside drain, right? The gray water pull is in the bumper compartment. Better double check my '74 manual...
01-08-2008, 01:22 PM
1 Rivet Short
1989 25' Excella
By The Bay
, Rhode Island
Could have leaked out on the trip home also...fill w/clean water and crawl underneath to look for drips...
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
01-08-2008, 02:30 PM
Central
, Mississippi
Bill
It wasn't leaking as they passed me on I-65
01-08-2008, 02:56 PM
1 Rivet Short
1989 25' Excella
By The Bay
, Rhode Island
Could have been dripping the entire weekend...a small drip would do it, and if it dissipated into the soil, may not have been noticed.
Just a thought...
Bill
01-08-2008, 04:43 PM
1975 Argosy 24
Collierville
, Tennessee
If this is the case then I had it backwards, the black water tank drains when I pull the one in the bumper compartment. Nothing drains when I pull the one street side in front of sewer outlett. I noticed no leaking anywhere but I had both valve handles pulled out when hooked into park sewer.
Heinlein
01-08-2008, 04:46 PM
1975 Argosy 24
Collierville
, Tennessee
Yeah we were trying to make a little time as the oldest had to be up early for school on Monday. We didn't break the speed limit though, don't need another ticket. I've decided in the future to keep it 5 under just to be safe and start out a little earlier instead of trying to make up time.
Heinlein
01-08-2008, 04:48 PM
1975 Argosy 24
Collierville
, Tennessee
I'll try this tomorrow if the rain has stopped. Thanks.
Heinlein
01-08-2008, 07:01 PM
2012 28' International
New Orleans
, Louisiana
If you had them out at the rally then the tanks should have drained all the liquid out. Normally you leave them closed and dump them when necessary this gives enough flow to flush out the solids. It is possible that the stem of the gate valve is broke and only the stem is pulling out leaving the gate closed. Time for the old flashlight inspection, look in the discharge pipe and determine the position of the gate valves. Good luck.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
01-08-2008, 07:05 PM
1975 Argosy 24
Collierville
, Tennessee
Yep, nxt time I will keep closed to build up some fluid to flush the solids as I had to do a lot of rinsing to get it all out here at home. Thanks for advice.
Heinlein
01-08-2008, 08:40 PM
Central
, Mississippi
In case you didn't see it, we almost had the chance to see the contents of several holding tanks when that SOB almost cut us off on I-10 in Mobile. It seems I announced the 'contents' on my black tank during his lane change...
01-08-2008, 11:30 PM
1975 Argosy 24
Collierville
, Tennessee
I wonder if that was the same one who's tire blew and took off the back lower side of his camper. One blown tire is gonna cost him some bucks. Still glad he got it pulled over without anyone getting hurt.
Heinlein
