Old 10-06-2011, 09:34 AM   #1
1969 31' Sovereign
O , Central,Florida.
Grey Water tank. is it really necessary?
Hey Y'all
I am in the nasty part of a 1969 Land Yacht rear bath extravaganza & I was told I need to add a Grey tank & some part of my brain says WHY? if you can't dump Grey on the ground {like back in 1969} then it has to stay in a tank right ?
What would be the difference if it was Black & Grey or the Black & Grey in separate tanks?
May seem like a stupid question but ....
I am going to have a custom tank made & so I just need to know is I need to divide it in half with 2 valves or I can do just one .
OK this is stopping me in my Drawings just wondering is killing my creative spurt.
SR66
Slowride66 is offline   Reply With Quote
Old 10-06-2011, 09:42 AM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Some places still allow the dumping of grey water on the ground. Limited, but still an available option. Is it one you will exercise? Only you can answer that. Resale value - someone may ask that in the future. Never giong to sell? Not an issue.
Boondocking? I have a little issue with hauling grey water in the portable container in the back of my truck. Black waste, I really hate to handle it at all. Seperation allows some selective waste disposal options. Grey tends to fill up faster, this could mean that if you only used the black tank you could extend the stay where you are by doing the washing outside the camper in tubs.
Moderizing? Do a full rebuild? Why noy do it to the current standards of todays RV's......
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 10-06-2011, 10:23 AM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I would keep them separate. You will fill up the grey tank much faster than the black. If you plumb both into one tank you will have to dump more often. I use a Thedford Smarttote for my grey water when I don't have full sewer hook up and it works out fine. I do not want to dump black water in the portable tank unless I have to. I can go 4-5 days on my black tank and we never stay at one camp site longer than that so I use dump stations for the black. If I were doing a complete belly pan off job I would install separate grey tanks. Vintage Trailer supply has custom tanks made to fit between the frame rails of vintage Airstreams and they can spin weld the outlets anywhere you want them.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 10-06-2011, 10:45 AM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
It would be nice to have a grey tank, but we've lasted for years without.
Just this morning, I ordered parts to do a partial work-around. You can keep the valve open while keeping the cap on the outlet, forcing the grey into the black tank. But that makes for a very messy dump. The parts I ordered are a thetford to valterra adaptor and a (valterra) temporary dump valve, both pictured below:
The plan is to turn the temporary valterra valve into a temporary thetford valve (cutting and glueing), then use it to hold back the flow instead of just using the cap. That'll make dumping a lot cleaner, even if the total capacity will be rather small.
Lynn
WBCCI 21043
Old 10-06-2011, 10:59 AM   #5
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
When remodeling my '72, I ran the sink wastewater into the black tank, but with a diverter valve to have the option of running it straight out the back like it used to. I kind of like the idea of having the soapy dishwater join the contents of the black tank (#1 only for us) to help-maybe-keep the tank somewhat "clean", so I usually have the valve switched that way. Works for us, maybe something like it for you too. PM me if you'd like more info. -tim
tphan is offline   Reply With Quote
Old 10-06-2011, 11:29 AM   #6
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by Slowride66 View Post
Hey Y'all
A lot of vintage owners w/o built-in gray tanks use an external tank (generally refered to as a "Blue Tote") to capture their gray instead of building one in.
Typically, gray tank capacity is quite a bit more than typical vintage black tank - many of which are only around 10 gallons or so. 10 gallons is not very useful at all for a gray tank - especailly if combined w/black.
One of the problems of only have one tank and it being used for both black & gray, it really becomes just a high(?) capacity black tank - it's no longer gray at all, it's all black.
We added both gray & black to our '56 (it had neither when built, it was a park model) because we do a lot of boondocking and field camping - by field camping I mean a rally in a field but with porta-potties brought in. In this case, it's usually on someones private property and they allow us (actually encourage us) to put our gray on the ground. The way our trailer is plumbed, our gray water goes into our gray tank then out the waste valve bypassing the black tank and allowing us to keep our black tank water "captured" so we are able to take advantage of this situation. This is also the way most modern trailers are set up. We have friends that have combined tanks that are not able to do this because they have their gray plumbed into their black tank. Even if they were to use their combined tank for only gray water at these rallies and utilize the porta-potties for their #1 & #2's, the tank is still comtaminated enough that they are not comfortable dumping their gray on the ground.
If it is plumbed in such a matter that the gray by-passes the black tank (whether into a built-in or exterior tank or tote), like in our old '64 and most likely your '69 you are fine. It's just when you have it plumbed so all your gray goes through your black tank to get out.
I know in our old '64 owner's manual it did explain the situation Lynn suggested...temporarily using a black tank to capture the greywater...the problem is that when the tank becomes "full" black and grey back up into your gray drain pipes and will come out at the lowest point - usually your shower. If it's just gray that does this...that's one thing, if it's combined...that's something completely different !
The way it was explained to keep having the messy dump session Lynn alluded to is to before removing the cap to dump, close the valve that way, you only have to deal with the usually less than a gallon of "mixed waste" captured between the valve & cap...and backed up in the lines if you waited too long. If the valve is left open when you remove the cap...then you are going to have to deal with the entire capacity of the mixed waste in the tank.
Bottomline, in my opinion is that:
1) Many people exist just fine without gray tanks - either by using hook-ups at campgrounds, a blue tote or letting it run on the ground where allowed.
2) Combined tanks are okay if:
a. You can by-pass with the gray and are okay with dealing with a little "mixed" when use of the combined tank is needed.
b. you only plan on camping where there are hook-ups
c. You don't mind dealing with mixed waste with a blue tote
d. It has enough capacity to capture your entire fresh water capacity so it can't back up into your shwer or gray lines
e. You only plan on boondocking for a day or two at a time or using it for "on the road stops" only
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 10-06-2011, 12:49 PM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I like having both tanks. never tried it without a grey tank. very few places I go allow grey on ground. If you are doing a big job anyway, why not? I use the grey water to flush the black water from the hose and fittings after a dump.
Old 10-07-2011, 07:16 AM   #8
1969 31' Sovereign
OK I get it & thank you all for the imput.
I am going to replace the tank its broken many times around the toilet flange & my freind works for a company that builds water tanks for fire trucks so a total custom tank is available
I have been thinking of the Black & grey & I think I migh try to add a valve from the grey to the black for a rinse out {in case #2's get bad} so 3 valves maybe 4 depends on how creative I get when I get there.
Seeing that I am replacing frame section & its 5" plus another 3 for the tank drop I was thinking of having a 8 " "c" channel made & it be simplified therefor I can make a bigger tank .
its approximatly 61 " Long by 43" Wide & 5 to 8 " deep with a angle to direct the gravity drain flow.
here's some pictures.
http://www.airforums.com/forums/f36/...out-78002.html
SR66
Old 10-07-2011, 08:48 AM   #9
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
I think this would work so long as you have the gt such that you could get it slightly uphill from the bt when dumping and flushing, whether by jacking up the front of the trailer slightly past level and/or having a couple of pads under the tires on the side that you want a little higher. Am I envisioning this the way you are?
Old 10-07-2011, 12:56 PM   #10
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
Black and grey tanks should be kept seperate. You don't want the bacteria from the black tank travelling into your kitchen or bathroom sink. They are plumbed similar to a home, but you are not travelling down the road in your homes.
I am pretty sure it is a rv code issue combining the grey water with the black. Thats why they are built with two tanks, its not a capacity issue.
I would definately keep them seperarate.
With that being said, I use a portable tote when boondocking, it isn't a big deal, but I often think about maybe adding a permanent gray tank.
2005 Ford Excursion V-10
Reese Trunnion Bar with dual cam sway control
Prodigy P3 brake control
seldencove is offline   Reply With Quote
Old 10-07-2011, 01:57 PM   #11
InsideOut's Avatar
1956 22' Safari
Images: 108
100% Agree...
It would probably come up into the floor of your shower before reaching your kitchen or bathroom sink though.
Don't think so...I know Airstream recently made (still makes?) a couple of models with combined tanks. I sure hope they build-in some sort of check valve to keep the tank from backing up like this in those models.
Shari
Old 10-07-2011, 02:08 PM   #12
InsideOut's Avatar
1956 22' Safari
Images: 108
P.S. I just checked the website, it appears that the 16' Sport, the International and the International Serenity still all have a combined tank - it's 21 gallons. The problem I see is the fresh water tank is 23 gallons - so where does the extra 2 gallons go when the combined tank is full?
Shari
Old 10-07-2011, 02:35 PM   #13
Ottawa , ON
Shari
Evaporation.
Old 10-07-2011, 03:54 PM   #14
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
A residential septic system, or any community sewer system, combines greywater with blackwater- it all goes down the same sewer pipe and then into the same tank or treatment pond. As Shari pointed out, if the AS tank gets full and overflows somewhere, it will be at a low escape point (tub or shower) rather than a high one (sink drain). Vigilance regarding waste tank capacity is especially necessary with a combined tank if you don't want a mess on your hands. Fortunately, this isn't too difficult with tank volume guages (or idiot lights like mine has) or looking into the toilet hole with a flashlight. This is also where a tote like yours comes in handy, to empty the tank frequently.
I've never heard of sewage bacteria crawling back up the pipes, swimming through the water of the sink (or tub) trap, and emerging on your freshly washed dishes, neither in a house nor in an RV. It's much more likely to end up on your shoes at a dump station.
As Shari also pointed out, it is not code for RVs to have separate tanks, just a convenient option.
That all being said, separate tanks is, I suppose, better in that it gives you more options and more capacity, but a combined tank is legal, safe (if properly plumbed and vented), and workable if your space, energy, or pocketbook is limited.
A friend used to say that "there's more than 1 way to skin a cat", which is an unpleasant image but nonetheless useful to keep in mind for your Airstream remodeling. Have fun- tim
Old 10-08-2011, 03:08 PM   #15
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
I stand corrected.
Due the single tank units have a backflow or checkvalves in them to stop sewer gasses from filling the trailer when your traps slosh dry under way? I wonder.
The bacteria I was refering to was not the raw sewage in the pipes, but the microscopic stuff you can't see.
I would still keep the tanks seperate.
Old 10-08-2011, 03:39 PM   #16
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I stand corrected.
By the time any microscopic bacteria could crawl all the way up from any waste tank to any place you might conceivably be exposed to it, it would be very dead. It's not like having a cup of raw sewage sitting next to a fresh cup of coffee, after all. Sewer check valves are called traps.
Old 10-08-2011, 04:13 PM   #17
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
I found this by searching bacteria...starting at post #11
http://www.airforums.com/forums/f444...light=bacteria
Old 10-08-2011, 04:54 PM   #18
1993 21' Sovereign
Since Airstream currently builds trailers with black and grey combined, and many Airstream and other RV's have bathroom sinks that drain directly into the black tank, and all those companies have much more money and design experience than a single individual that has never built one, I would take my chances with modern design. If there was really that much danger in combining them, in this age of liability and litigation, it would not be done.
Old 10-08-2011, 07:07 PM   #19
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Our experience when boondocking is that we use a dishpan in the sink and dump the water in the toilet. If there were a way to directly choose which tank the kitchen sink could drain too, we wouldn't have to do that. I think there have been some trailers made with the bathroom sink draining into the black tank. All this means the grey tank won't fill up so fast and there's always more room in the black tank. Then you can bring extra fresh water with you and maybe get another day boondocking.
I have seen it said you can dump dishwater on the ground, but if it goes into the grey tank, you can't. Tenters dump dishwater on the ground all the time after all. If you are boondocking in the wilderness you could dump grey on the ground, but whether this is legal I don't know. I do know lots of people do it. At parks and campgrounds, if everyone dumped grey water on the ground you'd end up with a swamp and more soap and food bits than the environment could absorb.
If you are rebuilding the plumbing, you have many options available.
Back in the '50's people dumped everything on the ground. They'd dig a hole under the toilet and cover it when they left. Enough people stopping there and they'd run out of fresh holes. I'm glad we are beyond that.
Gene
Old 10-11-2011, 11:37 AM   #20
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
As a short addendum to this thread (post #4), I thought I'd add in what I've since learned: I received the Thetford to Valterra adaptor and the temporary valve this morning and ran right out check if the combination would work. Not.
On 1967 rigs, there is very little space available between the sewer outlet and the opening underneath to connect the hose. It's ok with a regular hose as long as the connector is one of the curved ones, but the addition of the adaptor and temporary valve produces a space about an inch long to try to connect the hose. Not even shortening the adaptor/temp-valve (by cutting and glueing) would work out. THere just isn't enough space.
I'll keep the adaptor, but just put the temp valve into our stock of stuff to sell off here at the park. Somebody will come along with a very leaky system and pick it up.
Lynn
WBCCI 21043
Grey tank inlet help? brattwurzt Waste Systems, Tanks & Totes 1 08-21-2011 07:54 PM
Grey water tank for 1973 AS Tradewind 25' mblaksley 1970-79 Tradewind 4 06-07-2011 12:43 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
Grey Water Tank Flushes Toilet (to conserve fresh water) LittleRadio Sinks, Showers & Toilets 8 03-28-2011 10:10 AM
