Old 06-14-2014, 10:18 AM   #1
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Grey water PVC pipes leaking
I just discovered that the black PVC pipes leading to my grey water tank have a small leak. It is in the rear bath cabinet where there is a short stack of pipes with multiple joints. The one coming from the kitchen sink has a slight leak.
Since it would be a MAJOR task to disassemble the area, I just want to seal the pipe points. My first thought was black caulking (latex or sealant). Any recommendations on sealant?
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 06-14-2014, 11:01 AM   #2
SteveH's Avatar
Common Sense , Texas
I would try Amazing Goop. I've had good luck with it sealing leaks in plastic air conditioner drain pans and plastic water tanks.
Regards,
Steve
Old 06-14-2014, 11:31 AM   #3
1977 Argosy 24
Milltown , Wisconsin
I would use PVC glue, it will melt the pipes back together. That is what was used to assemble it in the first place.
ventport is offline   Reply With Quote
Old 06-14-2014, 11:52 AM   #4
1974 Argosy 20
Kooskia , Idaho
You can grind up some black PVC pipe and mix it with some PVC glue (work quickly) and make a paste to brush on the leaking joints. Clean the joints as well as you can to begin with. I have also seen string and PVC glue used. Wrap the string on the joint and saturate with PVC glue. I like the paste better though.
Old 06-14-2014, 02:09 PM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The drain pipe from the kitchen sink leading to the gray water tank broke on our '83 Excella. There was enough "play" in the broken section that I was able to get a connection rubber sleeve assembly with a metal wrap and hose clamps at Lowe's. I was able to separate the broken ends enough to slide the sleeve onto the pipe, re-align the broken area, then slide the sleeve over the broken area and tighten the clamps.
Perhaps you can cut the pipe and then do such a repair, that is if the pipe can be separated enough to slide such a sleeve onto the pipe after you make the cut.
There are several sizes and types of sleeves. Some are a different size on each end and may work on a joint.
Just a thought.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 06-14-2014, 03:27 PM   #6
Baltimore , Maryland
… or you could just use the correct cement. The pipe is not PVC it is ABS. Use ABS glue and it will fix the joint. (ABS cement is available at all the box stores)
Old 06-14-2014, 03:33 PM   #7
1974 Argosy 20
Kooskia , Idaho
How true, ABS is the black stuff. My mind slipped a cog when I repeated the OP PVC statement.
Old 06-14-2014, 05:17 PM   #8
ViewRVs's Avatar
1977 20' Argosy 20
I don't have any cracked pipes. Mine is leaking at the fittings.
Turns out, I do have a can of PVC cement and a few extra PVC fittings that will sacrifice their life to be donors for the PVC shavings!
Fred H.
Old 06-14-2014, 05:37 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
PVC glue will not work on ABS material.
There are some tapes out there specifically designed for wrapping pipes. Really sticky stuff.
Since there is no pressure in the drain line. The tape should work just fine.
If the joint is under stress. The glue job won't hold for long. The tape would have some flexibility.
Old 06-14-2014, 09:13 PM   #10
ViewRVs's Avatar
1977 20' Argosy 20
ABS - Got it! (not PVC, the pipes are black)
I'll try the ABS cement first and see if that resolves it. Thanks!
Fred H.
Old 06-15-2014, 05:14 AM   #11
'Not a crack, it is the fitting'…
Don't dump a bunch of goop on it then, fix the fitting. If you don't, it will just keep on leaking.
Yikes! Grey water tank leaking...please advise pamelake Sinks, Showers & Toilets 10 07-28-2014 03:46 PM
Plumbers, Help ! PVC fittings with ABS pipes alumascoupe Plumbing - Systems & Fixtures 18 08-25-2013 04:48 PM
Leaking pipes ngelin Fresh Water Systems 3 04-06-2009 01:50 PM
PEX vs. PVC - Which on for fresh water muddy_hollow Fresh Water Systems 8 07-11-2008 06:51 PM
Two PVC pipes? John Fresh Water Systems 11 12-06-2002 04:59 PM
