Old 09-06-2006, 07:52 PM   #1
1968 20' Globetrotter
Houma , Louisiana
Angry grey water problem in 68 GT
This last weekend we camped with no sewer hookup and had the problem of the grey water backing up into the tub. Is there a solution for this?
mimibeth is offline   Reply With Quote
Old 09-06-2006, 07:57 PM   #2
till's Avatar
Lisle , Illinois
Images: 108
Blue boy is the common name for the tote tanks. I have one for my 67. They hook up via short hose to your sewer pipe.
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 09-06-2006, 09:52 PM   #3
CaddyGrn's Avatar
1963 16' Bambi
1962 22' Safari
Yreka , California
Blue boy is it! Otherwise, even if you are using a blue boy... sometimes if you put a lot of grey water into the pipes at once, it will flow up into the tub. I have seen explanations why....somewhere.... so, my solution: when emptying the sink I do it slowly to avoid this problem.
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Bad Problem w/ Water Pipe rroessler Fresh Water Systems 20 06-05-2006 11:23 AM
Tote Tanks Dwight Waste Systems, Tanks & Totes 4 10-09-2002 06:13 AM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
Water Hammer melprice Water Heaters, Filters & Pumps 10 07-30-2002 01:10 PM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
