Old 07-09-2014, 06:22 PM   #1
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Grey water outlet doesn't have valve
On my 2000 Safari the grey water drain does not have a shut off valve and appears that it never had one. Once you take the cap off out comes the grey water. Is this a normal config?
mhilley is offline   Reply With Quote
Old 07-09-2014, 06:41 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
That's not normal for a modern trailer. Pre-'74 or so, that was the way things worked. There was no greywater tank at all and the greywater was just piped into the sewer connection downstream from the black valve.
A 2000 Safari should have a greywater tank with its own valve. Maybe someone broke off the handle and just left the valve in the open position? Someone with a similar trailer should be able to tell you what it should look like, or maybe even post a picture of their handles.
My '75 Argosy has the grey and black handles in completely different places, one inside the bumper-trunk and one near the sewer outlet.
David
DKB_SATX is online now   Reply With Quote
Old 07-09-2014, 06:53 PM   #3
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Did you look in the belly pan? There should be an access plate (otherwise you have to cut a piece out and make a plate for the new hole).
I suppose it is possible the factory never installed one by mistake and the previous owner(s) never thought anything of it.
Gene
Gene
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 9 10-02-2013 10:55 PM
12 v Outlet in overhead-plug doesn't fit wayneskid Sprinter and B-van Forum 6 05-27-2012 08:01 PM
grey water valve repair john hd Waste Systems, Tanks & Totes 33 12-21-2010 04:30 PM
WBCCI- Doesn't listen or just doesn't care Stream 1529 WBCCI Forum 30 09-29-2008 04:55 AM
'86 345 MH Grey Water Valve Extension Jim Tyrney General Motorhome Topics 1 11-17-2003 08:50 PM
