Old 06-02-2013, 12:07 PM   #1
m12
m12's Avatar
1985 25' Sovereign
queensbury , New York
grey tank valve trouble.
When I pull the grey tank valve every thing
Feels normal but the tank won't drain.it seems
There is no easy way to access the valve
Could it some how be cloged?. 1985 sovereign
Side bath.
m12 is offline   Reply With Quote
Old 06-02-2013, 12:15 PM   #2
1974 Argosy 20
Kooskia , Idaho
Sounds like either the handle has become detached from the valve, or the valve itself is defective. Probably you will have to do some belly pan surgery to find the valve and repair it. I doubt it would be a clog, especially on the gray water tank side.
Old 06-02-2013, 12:17 PM   #3
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
The obvious is there water in it? Not the vavle but the pipe from the tank. Open the vavle and put a wire coat hanger that you streached out in it and stand back.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 06-02-2013, 12:33 PM   #4
m12
m12's Avatar
1985 25' Sovereign
The tank is three quarters full. Thinking
About cutting the pan. ???
Old 06-02-2013, 01:26 PM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Try blasting water from a garden hoses up the drain and then stand back.
If that doesn't work try it through a sewer cap with hose outlet blackwater valve closed of course. It may develop some back pressure that way.
Try the easy stuff before opening the belly pan
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 06-02-2013, 02:24 PM   #6
I had the technician replace both black and grey valves last year on my 2004 Safari. The black was very hard to open and the grey wouldn't dump, similar to the symptoms you describe. The valves don't last forever.
I replaced the knife valves on previous r.v.'s as they were easy to get at.
I decided to hire the job on my Airstream as I saw no easy way to get at them. The work was expensive.
handn is offline   Reply With Quote
Old 06-02-2013, 02:26 PM   #7
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Some recent models have an access plate in the belly pan to access the valves. Depending what you put down the sinks, it could be clogged.
Gene
Gene
