03-05-2016, 09:16 AM
2015 27' FB International
Chapel Hill
, North Carolina
Grey tank valve rod broke
I have a 2015 Airstream 27FB International. When I went to dump the grey tank yesterday, the valve rod broke off, i.e. the cotter pin broke off of the rod connection. There appears to be no easy way to fix this without either taking the very large sheet metal belly off or cutting an access hole near the grey valve.
I'm really disappointed that this appears so poorly designed to access and fix. Although my AS is still under warranty, I can't get it into an AS dealer for at least a couple weeks. I'm on the verge of cutting an access hole near the grey valve. At least this will give me an access point if this ever happens again, which I suspect it will.
Any advice before I start cutting?
03-05-2016, 09:51 AM
2005 30' Classic
Burlington
, Ontario
Can't offer advice other than to say that I would do exactly what you propose cut an access hole.
I don't understand why AS can't be a bit more proactive in their design so as to make things such as dump valves - that will sooner or later need attention - more accessible. Doesn't seem too much to ask!
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
03-05-2016, 12:10 PM
1998 30' Excella 1000
Livingston
Stay away from the tank area. Mine only had 1/2" styrofoam sheet under it that was compressed, so only a 1/4" separated the tank from the steel pan.
Dropping the whole pan is a pain. My tanks had no straps supporting them. If your gray tank is full, all that weight will pull on the drain and vent pipes, which were the only thing that supported mine. You will benefit from cutting an access panel now, as it will come in handy when you have to service the dump valve(s) in the future.
03-05-2016, 02:25 PM
2008 25' Classic
Full Time
Probably the dealer will have to make the cut to repair under warranty so make an appointment to get it done by them. If you goof it up you may be stuck with a big $$ repair.
Maintenance access sucks in Airstreams
Kelvin
03-05-2016, 03:27 PM
2016 25' Flying Cloud
Venice
That is one of the reasons I chose a rear bed model vs the front bedroom as the rear bed model provides direct access to the dump valves located below the belly pan behind the wheels.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
03-06-2016, 10:24 AM
Chapel Hill
, North Carolina
Thanks for the advice
Ok, so I chickened out of cutting the hole now and dropped the whole pan. This was a pain, but doable. Actually, for me it was harder to get the pan off than to put it back on. I read the opposite in some other posts. As Siegmann pointed out, it is VERY important to empty the tanks first as their main support comes from the belly pan. There were also a couple of gas line supports in the way that were riveted in that I had to drill out. I replaced those rivets with screws. Another thing that messed with my head was that the rubber covers on the belly pan for the grey and black tank rods, on the side of the belly pan, were upside down (see pic), which meant both the grey and black tank rods had to be disconnected in order to drop the pan. I re-glued the rubber covers back on the pan correctly, with the slit facing upwards so the pan slides right over the rods, as it should have been.
I decided that I really wanted to get a complete picture of the underbelly of my trailer with the pan removed before I cut access holes. I was afraid that I might cut too close to the tanks. Also, I wanted to be absolutely sure that no screws to the access panel were in the vicinity of the tanks (even if the underbelly ever bottomed out and dented). I am currently in an RV park was able to do this with no special tools (other than a drill and socket set mainly). I will be taking the cover off again ( ) in a couple of weeks to make proper access panels (we'll be parked at my engineer brother's ranch then; he's got a great shop for this).
On another note, I called 3 possible Airstream dealers to inquire about this repair. The soonest we could get in anywhere was 2 weeks. One dealer actually said they were booked until September!! It's been my experience that getting warranty repairs in a timely manner is difficult, to say the least. Also, I picked up a new grey tank valve from the nearby Airstream dealer (25 miles away). I realized after I got back to install it yesterday that he sold me the wrong part! That was also bit frustrating. My old valve still works, it's just a bit tight. Anyway, everything is working now but I will be revisiting it in a couple weeks. Thanks to all for the advice.
03-06-2016, 11:36 AM
Livingston
Is Airstream still using the Thetford valve? If so, I'm surprised yours is getting stiff so soon. My black tank valve lasted over 10 years of full-time use before I had to replace it. Are your practices letting too many solids get into the gate area?
I think that the gray tank valve rod pin breaking with this new a rig likely an Airstream construction issue. While it may be extremely annoying that something that should be fixed by Airstream/Dealer at no time or cost to you, judging from your post, I think you will end up with a better end result, and also gain valuable knowledge and experience with your rig. Way to go!
03-06-2016, 01:42 PM
Chapel Hill
, North Carolina
Thanks Siegmann. Yes, the valve is Valterra with Thetford extension handle (not the more common screw in handle - http://www.vintagetrailersupply.com/...-p/vts-652.htm). We've had our trailer about 1.5 years (bought new). I've been double rinsing the black tank whenever we empty it to avoid buildup (unless there's a line of RVs waiting to use the dump). The grey valve just feels a bit stiff, and it eventually broke the extension pin. However, to my amazement, the pins that were in the Thetford handle were aluminum rivets! These will clearly not last long, especially if the valve is a little stiff like mine. Maybe my valve is ok, albeit somewhat stiff to move. I do not like these Thetford handles at all. In fact, the black tank handle connection would rub the slitted rubber flap whenever it's pulled open. A normal cotter key would rip the rubber flap apart from repeated use. So now I'm thinking about replacing both my dump valves with the more common Valterra screw in handle type. Vintage Trailer sells extension handles in a variety of lengths to accommodate. These just seem better than the Thetford rods. Any opinions on that?
03-06-2016, 07:07 PM
Livingston
Can't help you there. At the time I didn't know any better, and replaced mine with a Thetford valve (at 3 times the cost!) and kept the original Thetford extension handles too.
03-07-2016, 11:40 AM
1995 25' Excella
xxxxx
, xxxxxx
I would have just cut the hole and made an access panel. That is what my trailer's manual says to do when servicing the dump valves....I did it and made an access panel out of a scrap aluminum sign....Airstream should have put in an access panel from the start.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
