Old 09-21-2004, 08:14 AM   #1
1973 25' Tradewind
1964 19' Globetrotter
Centerville , Utah
Grey tank installation
I'm looking at buying a '73 Tradewind. Has anyone out there installed a grey tank on a 73 Tradewind? If so where and how difficult is it to do? Is it something that I let an Airstream certified tech do? Any advice would be great. Thanks.
tclay
Stormy Weather is offline   Reply With Quote
Old 09-21-2004, 02:59 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I did a grey tank on my 1971 Tradewind.
It resides between 2 crossmembers right behind the rear axle. It holds 36gal, which is good for about 2 days of conservative boondocking, with showers and cooking etc., more if you're using campground facilities.
It was not very difficult, but did require quite a bit of plumbing modifications.
If you're not sure, then you should have it done by an RV specialist.
A good quality custom tank will cost between $ 300 and $ 400.00, figure labor on top of that, plus plumbing parts.
It's not a cheap undertaking.
Uwe
www.area63productions.com
Old 09-21-2004, 05:35 PM   #3
1975 29' Ambassador
Reno , Nevada
see
http://sierranevadaairstreams.org/me...k/gallery.html
for one idea
Old 09-21-2004, 11:04 PM   #4
1973 31' Sovereign
Portland , Oregon
Images: 22
A clever idea...
Bryan,
That is a clever aproach for adding some gray water capacity.
Congratulations,
Malcolm
malconium is offline   Reply With Quote
Old 09-22-2004, 07:30 AM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I did something similar with my 25 gallon blue-boy...mounted it to the spare tire carrier way up in front, and ran a long piece of pex tubing all the way from the "exhaust" pipe to the front of the trailer. It worked....
eventually, I'll install a more "permanent" solution.
Uwe: do you know the source of your tank? I still have the pics you sent me way back when...having a hard time tracking down a specific tank make/model that will fit between the frame x-members. I priced out a custom made tank...cost prohibitive. ($400 + ).
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-22-2004, 10:42 AM   #6
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Originally Posted by Leipper
Is it safe to add that much weight to the back bumper? 12 gallons would be around 100 pounds. I guess if you were emptying before you left each camp site and not using it much when you stopped during the day it wouldn't be a problem.
Grant
DavidsonOverlander is offline   Reply With Quote
Old 09-22-2004, 11:07 AM   #7
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Grant
Grant,
I share your concern. i do not think that this is a good solution for travelling, due to the extra weight on the rear bumper.
Uwe
Old 09-22-2004, 11:15 AM   #8
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
There are many source for tanks in the $ 150 to $ 200 range, ( on the web) but they're all SOB type tanks. You might find one that's close, but I'd rather spend the money and have a solution that is permanent, safe and neat.
The 3 tanks for my Overlander will run over $ 1000.00, plumbing and frame work not included. The result will be a professional installation, with the proper venting and plumbing.
$ 400.00 for a one-off custom tank is actually a good retail price.
The frame rails on Airstreams are very thin and shallow, plus the trailers ride low to the ground. This makes tank selection and installation a bit of a challenge.
Uwe
Old 09-22-2004, 11:48 AM   #9
Wardinbb's Avatar
1964 24' Tradewind
Big Bear Lake , California
Maybe Off The Shelf
Hey Stormy,
Good luck with your acquisition and maybe the replacement. The PVC bumper design IMHO looks to be a suck job, a good deal of work for not a lot of result. The following link, http://www.incaplastics.com/, is one source for tanks. I also think that this manufacturer is or was an AS vendor.
Certified AS tech installation is a judgement call and subject to debate these days. Many members rely on their local AS dealer/service and have been pleased as punch over the years with the results. Others have horror stories, that are really almost unbelievable.
Ed
Wardinbb is offline   Reply With Quote
Old 09-22-2004, 12:01 PM   #10
1973 25' Tradewind
Centerville , Utah
Thanks!
All of your insight has been helpful!
tclay
Retrofit grey tank mod uwe Waste Systems, Tanks & Totes 33 03-08-2006 07:50 PM
Discovery...Grey Bypass!!! Tank Size?? blrpix Waste Systems, Tanks & Totes 9 08-12-2004 04:08 PM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
poor-man's grey tank Chuck Waste Systems, Tanks & Totes 9 09-05-2003 10:59 AM
No grey tank, no sewer hookup Safari Tim Our Community 8 07-11-2003 07:36 PM
