Old 08-20-2011, 09:00 PM   #1
brattwurzt's Avatar
1968 30' Sovereign
Baltimore , Maryland
Grey tank inlet help?
I have a question for the drainage experts. I have seen drains going into the side wall of the grey tank. I thought you had to enter on the top of the tank. Is entering on the side wall acceptable?
Here is my situation: I'm trying to use a grey tank from VTS that is only 4" tall, and I'm locating it between the bays in the chassis. I'm 6' 5" so my shower need to be as low as possible. I can use a trap in the next bay, but the drain entry point into the grey tank will be 1 1/2" from the top of the tank (on the sidewall).
I would appreciate all the input anyone has to offer.
dreamin' of streamin'
brattwurzt is offline   Reply With Quote
Old 08-21-2011, 08:54 PM   #2
1982 27' Excella
Mazomanie , Wisconsin
This probably isn't the answer, but you might have other options using this P-trap replacement. Google "Hepvo waterless valve". I haven't tried one but plan to when my renovation gets to that point. Perhaps someone else has used this. Happy plumbing.
jbib is offline   Reply With Quote
Grey Tank choice - ABS or Polyethylene? johnhh Waste Systems, Tanks & Totes 20 04-20-2012 06:00 PM
Adding/added a grey tank? rayandre 1970 - 1973 Overlander 3 08-12-2011 10:53 PM
Grey water tank for 1973 AS Tradewind 25' mblaksley 1970-79 Tradewind 4 06-07-2011 01:43 PM
Alternative to adding a grey tank, 60s rig eubank Waste Systems, Tanks & Totes 12 04-06-2011 03:54 PM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 01:43 PM
