Old 01-26-2015, 07:18 PM   #1
1967 24' Tradewind
grey/black water tanks
Can anyone direct me on suggestions of who can replace/repair black and grey tanks. I have a 1967 Tradewind…no grey tank and what seems to be an intact black tank. Fittings in bumper difficult to get at and no grey holding tank. It leaks onto ground or backs up in trailer. I live in Tampa, FL. Any suggestions on who can install a grey tank and approximate cost?
Linda
Linda
AIR #69671
ltanner is offline   Reply With Quote
Old 01-27-2015, 12:39 PM   #2
Gainesville , Florida
Jd Sanders in Alachua near Gainesville has done this. It's not cheap, though. Jim
Old 01-27-2015, 12:55 PM   #3
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Many owners of that era discovered just what you discovered—they only had a black tank. Many have found ways to add a grey tank and fix or replace the black one. There must be threads on how to do it—try to the search function. Or look for threads on the restoration menus.
There are tank and valve cleaners available. You may have a blockage at the valve (usually old, hardened toilet paper or something someone dropped in the toilet) causing some of your problem. Check out cleaners at RV stores and try that first to see if it clears up the black tank problems. If that doesn't work, then it gets nasty cleaning the tank.
You may not want to do it yourself, but you should know how it is done so you can make sure you don't get overcharged or ripped off.
Gene
Gene
Black and Grey Water Tanks arifarda Sprinter and B-van Forum 10 06-30-2013 08:51 AM
Installing black & grey water tanks markdenise Waste Systems, Tanks & Totes 11 01-16-2013 07:09 AM
Best fresh/grey/black water tanks in peoples opinions? solarstream Waste Systems, Tanks & Totes 2 10-30-2010 07:42 PM
Black/Grey water tanks 1968 Overlander StuartM Waste Systems, Tanks & Totes 4 03-22-2007 06:43 PM
