Old 06-28-2015, 02:27 PM   #15
1975 31' Sovereign
North Fort Myers , Florida
Most of the time when the valve leaks it's due to **** stuck in between the seal and the valve. Clean the poop out with a good brush or take it apart and clean it!
Two valves are for a reason as someone else commented on. You dump the black, then gray to flush.
When at a full hook-up the valves should always be closed until they need emptied or you'll get a giant chunk of goop stuck in the tanks. Leaving a campground you should leave several gallons of fresh water in the tanks to slosh around going down the road. This will help keep your tanks clean
TLBIJOU is offline   Reply With Quote
Old 06-30-2015, 10:20 AM   #16
1967 26' Overlander
Spartanburg , South Carolina
Interesting comments. Our 67 Overlander has the original Thetford black tank valve which has never leaked. I agree with dbj216 that it is frustrating that standard sewer hose fittings can't be used and Thetford fittings are not always easy to find when needed. I have just learned there is an adapter you can buy that lets you adapt standard to Thetford if you have room for it but I could not find it at either WalMart or Camping World. Amazon is my next try.
Jacob D is offline   Reply With Quote
Black and Grey Tank Valves Hard to Pull Ssmookler Plumbing - Systems & Fixtures 2 03-08-2015 04:22 PM
Minuet Water Valves - What is What? Grey and Black ply5013 Waste Systems, Tanks & Totes 1 11-16-2012 11:04 AM
Replacing black/grey with a larger grey whitney Waste Systems, Tanks & Totes 11 05-08-2012 06:47 PM
Black/Grey Water Valves - Drama on the road!!! AndyPenny Waste Systems, Tanks & Totes 1 07-19-2008 11:03 PM
'78 20' Minuet repair question: grey/black water drain valves Van All Argosy Trailers 4 01-06-2004 09:40 AM
