Old 01-23-2015, 09:29 AM   #1
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Gray Water Tank Sensors Update
After no responses I checked with the manufacturer of the SeeLevel II monitor system and the shorter tank sensors they carry will work with the VTS retro gray water tanks (4" high) they carry. I had seen where the SeeLevel systems were talked about on the Forum and was impressed. I hope this helps someone that has these tanks or other smaller height tanks and needs a tank monitor system. Hope this falls under OK things to post.
cole3444 is offline   Reply With Quote
Old 01-23-2015, 10:34 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I have the shallow VTS grey water tanks and installed the short SeeLevel gauges on them. I was told by the SeeLevel tech support guys when I was laboring over the decision, that as my gauges will cover the part of the tank where the wall thickens up as it approaches the corner, there may be some accuracy issues. I ran a bench test and slowly filled the tank with water, and it looked like they were pretty darn accurate, certainly accurate enough for the application. Can't offer any long-term performance anecdotes, as I am still laboring away at completing the rennovation.
One thing to be aware of is that you have to place the gaues strategically so that they are not near any metal. Proximity to metal screws them up.
good luck!
Old 01-23-2015, 07:30 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I have had good luck with my SeeLevel sensors and readout. Garnet did an excellent job helping me solve a problem during my installation. Turns out I had DC voltage ripple generated from my 25 year old converter. The instrument would work without shore power, but when I plug in shore power the read out went manic. A new converter solved the problem.
My sensors are pretty close to the frame rail, so i put a sheet of rubber over the sensors to insulate them. No problems on that end.
My tanks are 9" deep, but I believe there is a cut point at 4".
David
Name:	1404 Waste Tanks See Level Senders.jpg
Covert fresh water tank to a gray tank cole3444 Waste Systems, Tanks & Totes 3 03-25-2014 06:31 PM
Water tank sensors fell off MILATV Sprinter and B-van Forum 10 09-21-2013 07:27 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
Holding Tank sensors andyfuson Waste Systems, Tanks & Totes 43 01-09-2009 10:16 PM
Waste, Gray, Water tank sensors. soldiermedic Electrical - Systems, Generators, Batteries & Solar 0 11-20-2006 10:13 PM
