Old 11-09-2006, 09:46 PM   #1
cookeville34's Avatar
Auburntown , Tennessee
Send a message via Yahoo to cookeville34
Gray water tank?
Hi, I had assumed my 79' Sovereign rear bath 31' did not have a gray water tank, but after reading other post I'm now confused.
Does it have a gray water tank? If it does where is the drain hookup? I know where the black water tank drain is, are the connected somehow?
1979 Airstream Sovereign International, 31'. VIN# I31T9J0162
1992 Buick Roadmaster Wagon, 5.7L - V8, stock 5000# tow rating, posi, aux trans cooler, rear coil over shocks, 2" rear spring lift kit, flowmaster exhaust.
cookeville34 is offline   Reply With Quote
Old 11-09-2006, 09:52 PM   #2
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Yes you have a Grey Tank, all Airstreams since 1974 have them. It is connected to a common dump with the Black Tank, To drain it; hook up the Stinky Slinky and then pull the Black tank valve and let it drain. Then pull the dump valve for the Grey water (Wash Water) tank. Let it drain clean up the Slinky and your done.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 11-19-2006, 04:38 AM   #3
Grey tank
I'm still having a little trouble figureing out the drain system, I can only find one drain valve located under the left rear bumper, I beleive this is the black tank, since the toilet appears to dump directly into it.
Just outside the drain valve, but inside the drain connection is an outlet about 2 1/2" that appears to be factory and bypasses the drain valve.
When you pour water into the sinks water comes out the bypass on the black tank drain.
On another note is there a spare mounted some where on this trailer? Whats left of my owners manual shows a spare mounted under the frame next to the tongue., but my belly pan is intact and its a complete unit with no doors or open sections.
Old 11-19-2006, 05:56 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The spare is an option you do not have. The previous owner may have eliminated the gray water tank the unit came with. Photos would help us to tell you. Otherwise, you might contact someone in the local WBCCI who could come out and help you. Or for money take it to the local RV dealer and they will help you do a checkup on the unit and make repairs as necessary.
Old 11-19-2006, 06:36 AM   #5
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Should look somethin like this....
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 11-19-2006, 07:48 AM   #6
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
What you need is a buddy to come over and show you the systems and how to use them. Maybe one of the many members in Tennessee will step forward. If not plan to go to a rally and do not be afraid to ask questions. You could also check to see if your local unit of the WBCCI (Wally Byam Caravan Club International, The Airstream Club believe it or not) winter luncheons. Your questions are common to those of us who bought our first AS used without instructions.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
No Grey Water Tank????? Anna Waste Systems, Tanks & Totes 16 11-17-2002 07:33 PM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 06:09 AM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 10:45 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
