Old 02-08-2012, 03:23 PM   #1
1970 23' Safari
Fresno , California
Gray Water Question
We have a grey water question. We recently bought a 1970 23' Safari with the rear bedroom on the street side and a shower on the driver side. We want to install a gray water tank, What size or how many gallon tank should we install and are most fitting under the belly?
barbaralarae is offline   Reply With Quote
Old 07-14-2012, 09:27 AM   #2
1989 29' Excella
greenville , South Carolina
73 argosy grey water
if you hook to campground sewer will gas go through grey warer system into camper???
muletuff is offline   Reply With Quote
Old 07-14-2012, 09:29 AM   #3
1989 29' Excella
if you hook a 73 Argosy to campground sewer will sewer gas come through the grey water system?
Old 07-14-2012, 10:57 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the shower is currently TRAPPED above the floor level you just have to get under there and measure what will fit. The sink should be trapped just under the bowl and no problem.
There are a number of companies on line that make tanks and have stock sizes. Many will install the connection for you if given the measurements.
Keep in mind you will have to figure a way to get a vent up to the roof. If the area is small I have used 2 tanks. Cross connecting them at the bottom is not the problem you will have to make a connection across the top to vent the second tank to the main tank. May be a problem depending on the cross bracing of the trailer frame.
2004 Excursion 4x4
Old 07-14-2012, 09:10 PM   #5
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
You can put anything from a 15 gallon to a 35 gallon + depending if you want it to hang bellow the belly pan and where you are able to put it.
First I would try to figure out where it is going to go under the trailer. This may mean dropping the belly skin. You can look at tanks here, this is where I got mine.
RV Water Tanks & RV Holding Tanks
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Gray Water Tank Flush Road Geezer Waste Systems, Tanks & Totes 6 02-01-2012 06:23 PM
345 Shower filled with gray water! sharptalk Sinks, Showers & Toilets 11 07-19-2011 04:30 PM
Water supply question at a state park. meadowlm General Repair Forum 6 06-07-2011 10:57 PM
Noobie black water question pappy19 Waste Systems, Tanks & Totes 9 05-25-2011 09:52 PM
