Old 04-27-2014, 06:33 PM   #1
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Gray tank vent
I will be adding a gray tank to my Caravel. It will be below the floor. The black tank will be eliminated as I am going to a composting toilet. It can be vented out the existing black tank vent stack.
The question is : can I vent the new gray tank out the vent that the kitchen and bath sinks vent out of? Or do I need to use the vent stack that the black tank uses now?
Any ideas or suggestions are appreciated.
Sent from my SAMSUNG-SGH-I747 using Airstream Forums mobile app
Dingo Girl is offline   Reply With Quote
Old 04-27-2014, 06:36 PM   #2
DFlores's Avatar
1968 22' Safari
Yes, I am venting my grey water tank via my sink vent. My black water tank is vented via bath lavatory vent
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 04-27-2014, 09:07 PM   #3
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
You can vent it into either one. If you tap into the one with the sinks, Just make sure where you tap into is higher than any drain.
Also if the black tank was the only thing on that vent, and you are not going to use it, you should remove it and patch the roof or cap the pipe where it comes out of the roof so rain does not get in.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 04-28-2014, 03:57 AM   #4
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Thank you for the help!
The black tank vent will be used for the composting toilet.
Covert fresh water tank to a gray tank cole3444 Waste Systems, Tanks & Totes 3 03-25-2014 06:31 PM
Tank level monitor suggestions for new black/gray tank mrsfixit Waste Systems, Tanks & Totes 5 06-28-2012 06:39 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
Gray water vent issue Dan Clayton Waste Systems, Tanks & Totes 7 10-29-2010 09:11 PM
Anybody know if a black tank will fit in the gray tank space on my TT? Aage Waste Systems, Tanks & Totes 9 02-24-2010 04:13 PM
