Old 09-06-2016, 04:06 PM   #1
2016 20' Flying Cloud
Lee , Massachusetts
Gray tank sensor way off
The tank sensors in our gray and black water tanks are way off in our 2016 20 footer. The gray reads at 44% after just a 3 or four gallons, and the black registers nothing (zero) until used 15-20 times.
Any ideas?
Bobwes is offline   Reply With Quote
Old 09-06-2016, 08:25 PM   #2
2011 27 FB International
Vancouver , British Columbia
You can reset the system. I did mine, it's more consistent now, but i was too afraid to fill the black/grey 100%, so now they all register full when probably only half full. I'll have to do it again.
I dont remember the sequence on the micro pulse monitor and the exact steps, it's in the manual. Essentially you set the monitor into a configure mode with all the tanks empty. you set the empty level, fill a tank, set the full level, empty it. repeat for other tanks.
mixedpuppy is offline   Reply With Quote
New MicroPulse Sensor and re-cal... post mortem on old sensor RFP General Repair Forum 10 10-25-2017 07:29 PM
Tank level monitor suggestions for new black/gray tank mrsfixit Waste Systems, Tanks & Totes 5 06-28-2012 06:39 PM
gray water sensor dead mistermcfrug Electrical - Systems, Generators, Batteries & Solar 3 04-13-2012 04:25 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
Anybody know if a black tank will fit in the gray tank space on my TT? Aage Waste Systems, Tanks & Totes 9 02-24-2010 04:13 PM
