Old 07-22-2009, 07:13 PM   #1
1965 20' Globetrotter
New Braunfels , Texas
Gray and Black Water Tank
I have a 65 Globetrotter. After finishing the plumbing system about 90% I am looking for the gray and/or black water tanks. I see the one sewere type drain under the back of the trailer, but does anyone know if this trailer has a gray water tank or not? I thought I remembered reading that some of the older trailers didn't have them and was checking to see if ours did or not. Thanks!
Skycop is offline   Reply With Quote
Old 07-22-2009, 07:16 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
You do not have a gray water tank, only a black
Old 07-22-2009, 07:19 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Grey tanks were not installed until the mid 70's.
Richard
Old 07-22-2009, 10:05 PM   #4
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
My '64 Safari has a combination black and grey tank (one tank total) that holds a whole 8 gallons! Needless to say, the renovation/remodel will include separate grey and black tanks (two tanks total!), and they will be larger than 8 gallons total.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 07-22-2009, 11:10 PM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
1974 to be exact (though the Excella 500 had one in 1973).
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-23-2009, 03:53 PM   #6
Thanks guys!!!!
Old 07-23-2009, 08:16 PM   #7
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison , Michigan
Images: 8
We have a 62 Bambi....Does anyone know about how much it would cost to have an AS dealer add a gray water tank?........Thanks!......(is it even possible to do?)
62bam is offline   Reply With Quote
Old 07-23-2009, 09:17 PM   #8
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
Here are some links to our gray tank installation in our 62 22' Flying Cloud. We removed the black tank which was under the toilet and replaced it with a composting toilet. No more black tank!
http://www.airforums.com/forums/blog...on-update-166/
http://www.airforums.com/forums/blog...tallation-144/
FLYNCLD
FLYNCLD is offline   Reply With Quote
Old 07-24-2009, 07:27 PM   #9
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison , Michigan
Images: 8
FLYNCLD...Thank you...GREAT photos and info........Now I can see that it's a "GO".
Old 07-24-2009, 07:51 PM   #10
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Tanks
I`m in the process of doing tanks on my 63 GT,black tank street side rear,gray tank in front of axle street side. Dave
Picture went to never never land
easyride is offline   Reply With Quote
04 28 safari 70 gallon combined black and gray tank safari 28 Waste Systems, Tanks & Totes 6 11-07-2007 10:53 PM
Black and gray water tank Judy Barde Waste Systems, Tanks & Totes 11 12-11-2006 01:43 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 07:38 PM
no gray or black water holding tank pahadley LP Gas, Piping, Tanks & Regulators 8 11-11-2004 08:11 PM
Replacing black and gray tank level indicators nickcrowhurst Waste Systems, Tanks & Totes 4 12-30-2003 09:42 AM
