Old 06-06-2010, 08:55 AM   #1
Tradestream's Avatar
1962 24' Tradewind
Panama , New York
Glass on flanges for black tank
I am refurbishing my black water tank out of my 62 Tradewind and wanted to know of a source for valterra glass on flanges and a new toilet flange insert.
thanks Dan
Tradestream is offline   Reply With Quote
Old 06-06-2010, 09:13 AM   #2
thanks Dan
Dan.
Use plastic flanges.
They are available at Home Depot as well as many hardware stores.
Make sure you roughen the surface of the tank in the area that you will be "glassing". That will help bonding the new glass to the old.
Old 06-06-2010, 09:53 AM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Here are a few things that I ran into putting my new black tank in my 68 Trade Wind ( a nice new fiberglass one from Inland). Make sure of the position of the black tank before you cut the hole. I started with measuring the old one and thought better of it. Glad I did. Since I replaced the floor I had to cut a hole for the vent and toilet. I put the bathtub and rear wall plastic piece back in the trailer, that way I could get the toilet in the perfect location. Pushing the flush lever opened the bottom of the toilet and I made a mark in the dead center on the new floor. Cut the hole in the floor and then raised the new black tank into position. After a little tweeking to get it centered just right, I marked the location on the top of the new black tank through the hole in the floor. Sanded and glassed in the flanges for vent and toilet and all went back together. One problem I had was the coupler between the flange on the tank and the closet flange was too long and I could not get the black tank up against the floor. I could not find anything at the local plumbing supplies that would work. I finally bought a PVC coupler with male threads the correct size for the flanges. Cut the threaded part off with my dremel. Because the pipe fitting has tapered threads, I then had to "square" the sides on my sanding table. Doing this will flatten the threads on the bottom part so I then had to reshape the lower threads with my dremel tool. Took about 45 minutes, but I now have a short threaded coupler to connect the tank to the closet flange and it is short enough to allow the black tank to be against the floor. Finally, I shimmed the bottom and the sides of the black tank with rigid foam insulation board so the black tank now fits just right into the galvanized box.
Hope this helps.
Anybody know if a black tank will fit in the gray tank space on my TT? Aage Waste Systems, Tanks & Totes 9 02-24-2010 04:13 PM
Cover rusted oven door with black glass? RichHog Stoves, Ovens & Microwaves 11 12-02-2009 01:56 PM
Do I have to use the Black Tank? jimsease Waste Systems, Tanks & Totes 8 08-09-2006 10:22 PM
Black tank Gunnyusmc All Argosy Trailers 4 07-19-2004 04:42 PM
Black Tank Gunnyusmc Waste Systems, Tanks & Totes 3 07-02-2003 07:38 AM
