05-22-2018, 06:56 PM
2002 30' Classic S/O
Fleming Island
Furnace Duct to Waste Tanks?
I have read many times about the furnace being ducted to the tank area to keep them from freezing. In the process of replacing my dump valves I have dropped the pan and been all over (actually under) the area of the pan covering the black and gray tanks and I see no evidence of a furnace duct. Is this only for the fresh water tank? Am I missing it somehow?
Al
05-22-2018, 07:19 PM
2004 19' International CCD
Longmont
My understanding is that it depends on the model and year. Some use furnace ducted to tank areas, others have dedicated heating elements. Our 2004 19 CCD uses ducted heat from the furnace.
What year and model do you have?
05-22-2018, 08:06 PM
Fleming Island
2002 Classic 30 Slideout. No heating elements I am aware of.
Al
05-22-2018, 09:47 PM
Longmont
Al
Looking at the quick specs on the Airstream page for your model and year, I don’t see it listed as standard or an option. Perhaps it wasn’t available, or I’ve missed it ? https://www.airstream.com/service/document-archive/
05-23-2018, 06:31 AM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
Our 91 has the furnace directly over the tanks and has an open duct straight to the tanks.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
05-23-2018, 09:35 AM
2004 25' International CCD
2012 25' International
2019 27' Tommy Bahama
slaton
Al
We had a 2004 International 25', and both gray and black tanks froze. Heat lamp and fan took about a day to help unfreeze.
05-23-2018, 11:05 AM
1985 31' Excella
st. Paul
, mn
Not sure when / if they changed what ?
But all were advertised as heater basements , well there are no basements unless the new ones ?
My 85 has ducts laying on top of tanks going from front to back [ but no open part of duct to that area .
From the furnace under kitchen cabinets & other cabinets - the duct lays on the floor , at the point of the tanks the floor is cut-away [ also the winter drain is there ] and duct lays on tanks , then back on top of floor to get to bedroom , also below floor to other side of trailer - to bathroom and then above floor to duct .
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
05-23-2018, 12:23 PM
Oswego
I believe, in your unit, you will find 2 ducts. One disappears through the floor right by the furnace. This one is for the fresh tank. The other one is under the closet floor and disappears under the floor right around the black tank vent stack. This one heats the black and gray tanks, as they are in the same pan. I have long been waiting for an excuse to drop the belly pan in order to better route and insulate the pan areas.
-Rich-
05-23-2018, 12:27 PM
2002 30' Classic
Ocala
My 2002 Classic (No SO) has ducts running into the under floor area. If you open the area to your water pump you will see a 2" branch flex pipe into the under floor area and in mine. if I take out the large drawer under the Microwave you can also see the 2" pipe.
05-23-2018, 12:30 PM
2004 22' Safari
Albuquerque
, New Mexico
I have a 2004 22 foot Safari. It has 2 switches above the information panel for tank heaters. I haven't tested them, but the lights go on when I engage the switches.
05-23-2018, 03:04 PM
Fleming Island
Thanks everyone. Well, I didn't drop the tanks so I can't attest to what might be above them, but all around them looking up I can see the subfloor. I'll take another look before I put the pan back on, particularly in the closet area and under the microwave cabinet. Both of those areas are about even with the front axle which is just behind the freshwater tank, however.
There's a lot about the slideout that makes me think they adapted non-slide parts, and not always completely or successfully. I found I had to drop the rear axle to remove the waste tanks pan as the axle was flange was bolted over (under) the side of the edge of the front flange of the tank pan. They may well have not run a duct to the waste pan area.
Al
