Old 07-12-2016, 04:30 PM   #1
1988 25' Excella
louisburg , Missouri
Frozen closed dump valve
I have a 73 Land Yatch Tradewind. It has a single holding tank with the dump valve located in the center rear of the trailer. The valve appears to be frozen closed. Do I have to have the valve replaced or is there some kind of fix? Thanks for any help
dtutko1 is offline   Reply With Quote
Old 07-12-2016, 05:38 PM   #2
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
There is dump valve lubricant available where they sell RV supplies, I think it's mostly coconut oil.
Don't pull too hard on the handle it will break off, voice of experience here.
The original valves can be rebuilt with new seals but as long as you're taking things apart you'd be better off replacing the valve. I did mine after the handle broke
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Frozen Sewer and Dump Valve pepsigns Winterizing, Storage, Carports & Covers 20 01-28-2016 05:37 AM
Frozen Dump Pipes bertheep Waste Systems, Tanks & Totes 11 11-23-2013 05:42 PM
Frozen gas valve robert claus LP Gas, Piping, Tanks & Regulators 6 05-10-2011 07:18 AM
HELP frozen black water tank, not valve wildwoodmusi Full-Timing, Winter Living & Workamping 21 01-20-2009 03:37 PM
frozen black water dump valve Rick Alston Waste Systems, Tanks & Totes 6 10-28-2003 01:17 PM
