Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 03-24-2007, 10:12 PM   #1
1976 31' Sovereign
Charlotte , North Carolina
Exclamation Fresh Water Tank Access
My 76 AS Sovereign leaks around the front edge of a large metal box framed square section in front of the wheels. It hangs slightly lower. Being a new first owner of an older AS, I am assuming that this is from my fresh water tank. Is there an overflow or vent and is it leaking due to too much water or possibly leaking thru the small holes that some models have for heat from a blower pipe from the furnace? Is there an access door in the floor inside?
Please where do I start. The whole plumbing layout is a mystery to me.
I guess that being an older tank, I should consider total replacement and also to the grey water and black water tank.
Please!!!!!!!!
Some good logical advice and links to helpful threads with drawings & explanations.
Badco8 is offline   Reply With Quote
Old 03-24-2007, 10:17 PM   #2
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Welcome to the forums!
It really depends on where it's leaking. My '72 was leaking at the fill tube just inside the trailer and was leaking down into the square area you describe. It MAY not be serious, don't panic yet.
If it turnes out to be the tank, there are others here who have done that and can advise you.
Good luck,
Dave
Fyrzowt is offline   Reply With Quote
Old 03-24-2007, 10:22 PM   #3
1976 31' Sovereign
Thanks Dave
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
what holds black water tank in place tw64 1959-69 Tradewind 3 06-16-2004 11:05 PM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 08:52 AM
What Grey Water Tank?? niftypkg Waste Systems, Tanks & Totes 6 09-04-2002 07:12 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
