Old 01-22-2016, 07:08 PM   #1
DebTip
1957 16' Bubble
1954 22' Flying Cloud
Kingsport , Tennessee
Fresh water fill
I need a water fill neck for a 1950s airstream. Does anyone have suggestions on locating an original one or pictures of one that I could duplicate? The part I need has a cap on the outside and passes through the trailer wall to the inside fresh water tank. Any info would be greatly appreciated.
Thanks, Steve
debtip is offline   Reply With Quote
Old 01-22-2016, 09:00 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
My sis has a 1960 that had this water fill. This is a repro from VTS.
Cast Water Fill Neck & Cap
reinergirl is offline   Reply With Quote
Old 01-22-2016, 10:20 PM   #3
Images: 59
The repro is very similar to the original. Original was an aluminum casting. The aluminum pipe has a Shraeder valve tapped into the side and a regular brass hose bib tapped into the cap which served as a hose refill.
Old 01-23-2016, 08:37 PM   #4
Kirkland , Washington
If you choose not to go with an original style, the stainless type made for boats is an attractive option. This is the one I'm planning to use:
54fuselage is offline   Reply With Quote
Old 01-24-2016, 07:29 PM   #5
DebTip
1957 16' Bubble
Thanks so mush for the picture of the original one. I really wished I could find one like this. Do you have one for sale by chance? Thanks, Steve
Old 01-24-2016, 07:58 PM   #6
Images: 59
No, they only came one per trailer.
Old 01-24-2016, 08:06 PM   #7
DebTip
1957 16' Bubble
Could you give me the dimensions for the original? Flange dia. Cap dia. length it protrudes from trailer not counting the hose bid and the inlet dia.
Old 01-24-2016, 09:30 PM   #8
Images: 59
Sorry, but the trailer is put away for the winter and I can't get to it.
Anyone else?
Can water heater fill from fresh water tank? phann Water Heaters, Filters & Pumps 14 02-04-2018 01:10 PM
Noobie - how to fill fresh water tank? Bohemian Fresh Water Systems 26 10-18-2016 01:51 PM
Fresh Water fill from City Inlet question Distantdrummer Fresh Water Systems 7 07-15-2010 05:38 PM
Fresh water tank fill jfowler218 Fresh Water Systems 4 04-21-2009 07:36 PM
Fresh water fill Safari Tim Fresh Water Systems 6 05-20-2007 03:50 PM
