Old 10-21-2019, 10:53 AM   #1
2013 23' FB International
Methow , Washington
Fresh out of RV antifreeze!
Can anyone think of a downside to using conventional auto antifreeze (ethylene glycol) in drain traps ?
Rufrider is offline   Reply With Quote
Old 10-21-2019, 11:21 AM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
It is poisonous and you will be dumping hazardous waste into the sewer system of the campground or municipality when you empty the tanks in the spring.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 10-21-2019, 11:29 AM   #3
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Extremely toxic and poisonous. It could kill you. And dumping it in the Spring to anything other than an approved sight, is illegal.
thewarden is offline   Reply With Quote
Old 10-21-2019, 11:48 AM   #4
Mollysdad's Avatar
WalMart carries it.
Don't use the auto stuff.
Old 10-21-2019, 12:06 PM   #5
1981 31' Excella II
New Market , Alabama
I would not do it. I have never heard of a trap breaking from ice anyway. As others have said Walmart has the stuff. You could also plunge the water out with a toilet plunger.
Perry
Old 10-21-2019, 02:47 PM   #6
richw46's Avatar
Lexington , Kentucky
Going the other way...what would be the benefit of auto antifreeze over using RV antifreeze? Go to the liquor store and get cheap vodka, gin or neutral grain spirits.
Walmart, Home Depot, Lowes, Camping World or any RV service place will carry RV antifreeze. It's safe, cheap and environmentally friendly.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 10-21-2019, 02:52 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
https://www.hemmings.com/blog/2014/0...of-antifreeze/
https://www.google.com/amp/s/www.foo...glycol-is.aspx
Old 10-21-2019, 02:56 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Just my take, but from what I have read, it seems like Dex Cool might be acceptable.
Old 10-21-2019, 03:02 PM   #9
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
No. Chemical Name CAS Number Wt %
01 Monoethylene Glycol 107-21-1 V HIGH
02 Components determined to be non hazardous Proprietary LOW
03 Denatonium Benzoate 3734-33-6 V LOW
PROPORTION (%weight per weight)
V HIGH > 60, HIGH 30 - 60, MED 10-29, LOW 1-9, V LOW < 1
That is from the MSDS for Dex Cool. It is just plain ethylene glycol, like antifreeze has always been. Deadly to any living creature. If you are concerned about that, then you need RV antifreeze or Vodka. However, there has been a lot of vehicle antifreeze poured down the drain to sewer systems over the years.
Larry
lsbrodsky is offline   Reply With Quote
Old 10-21-2019, 03:35 PM   #10
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I use cheap vodka.
Old 10-21-2019, 03:41 PM   #11
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Other thing you could do is take a shop vac, reverse the hose to the output side, wrap some rags around the hose and and put it into the drain. I guarantee that this will force out all water from the trap. Downside is you might get some smell from the grey water tank and obviously if you have a single black/grey tank this is a nono. I used to use this technique years ago on my Hi-Lo. Now I have enough unused antifreeze from the two gallons I use, to pour additional anti-freeze into the drains.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-21-2019, 03:59 PM   #12
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I was going to reply, but I think you get the idea.
2019 Ford Expedition Platinum
Old 10-21-2019, 05:50 PM   #13
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If indeed the local supply has been wiped out by your neighbors stockpiling it for the coming global cooling event (next month) ..... there are a number of places that will ship it in to you. One of many:
https://www.amazon.com/Camco-30767-F...s%2C157&sr=8-2
Un-mentioned above, the "rv stuff" is compatible with the materials the traps are made out of. There's no guarantee that is the case with automotive antifreeze.
Old 10-21-2019, 07:20 PM   #14
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Perry
You heard it now, I just fixed a 70 Safari broken sink trap and a 60 Ambassador tub trap both frozen broke last winter.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Mid-bath T1N. Antifreeze into fresh water? Lotus54 Sprinter and B-van Forum 24 02-10-2017 08:52 PM
Help!! Antifreeze Leaking Out of Bottom of Trailer breezyway Winterizing, Storage, Carports & Covers 4 10-05-2014 05:01 PM
Freezing RV Antifreeze Raptorrider2001 Winterizing, Storage, Carports & Covers 1 01-13-2003 02:33 PM
RV Antifreeze Quality jcanavera Winterizing, Storage, Carports & Covers 8 11-27-2002 04:32 PM
Can I use "regular" antifreeze in my holding tank? Luckydog Airstream Motorhome Forums 6 11-25-2002 08:01 AM
