Old 02-15-2016, 06:27 AM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
You need one of these…
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-15-2016, 06:28 AM   #16
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
One could hope it deterates at a high rate....
Old 02-15-2016, 06:45 AM   #17
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I wonder if you could call in a plumber to put a flexible scope into the holding tank to see where the fork is and then retrieve it with a flexible retrieving claw.
Kelvin
Old 02-15-2016, 06:52 AM   #18
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Sometimes in life you just have to get your hands dirty.
MICHAEL
Old 02-15-2016, 07:22 AM   #19
Kevin245's Avatar
The only real harm in having the fork in the tank is if it gets caught in the dump valve. Sure it could cause some undesired wear sliding around inside the tank if it were to remain there long term, but the gate jam scenario would be my worry.
Here is my approach:
Step 1:
Check similar silverware you have in your drawer to confirm that it is capable of being retained by a good quality magnet. If the fork will cling to the magnet then buy a circular, or threaded magnet that can be tied to a heavy gauge mono filament line and bob for the fork for few minutes to see if you have any success. If you don't then here is what I would do when I am ready to depart, or the next time I travel with the AS.
Step 2:
Make sure the tank is 1/4 or more full of water, or waste. Lower the magnet so that it rests on the bottom of the tank then allow the toilet flapper to close leaving several feet of mono filament line extended out of the toilet. Secure the loose end of the line to a secure anchor point such as a fixed point in trailer, and proceed on your trip. The best chance of "catching" the fork will be during periods of movement induced by normal travel.
If the fork will not cling to a magnet then you are reduced to poking around with a grabber like Protagonist shows, or drooping your drain line (Think P-Trap) and trying to capture it during a flushing operation.
Eleanor Roosevelt
Old 02-15-2016, 07:51 AM   #20
Long Island , New York
Or before you do anything, get someone with really small hands, and long arms, equipped with a long rubber glove, and reach down into the tank to feel for the fork . . .
Sound gross to some, but it may work . . . and it is a KISS solution for sure . . . [keep it simple stupid] . . .
PS -- cover toilet seat etc. with disposable protection . . .
PS2 -- good ideas Kevin.
Old 02-15-2016, 08:31 AM   #21
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Removing the toilet is really not that difficult and since your trailer is new should came off easily. Then you have the ability to get a flexible light and mirror in the access hole and determine how to grab it.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 02-15-2016, 09:30 AM   #22
2016 30' Classic
The flex hose pic brought back memories I had summer of 2014 in the MH. Too much TP clogged it up. Happy ending, but not fun at the time. Good luck with the fork!
caseywsj is offline   Reply With Quote
Old 02-15-2016, 09:40 AM   #23
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Time to buy a new fork. He said not having done the same boo boo, yet.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 02-15-2016, 09:44 AM   #24
Cloud10
smccollister's Avatar
2010 25' FB Flying Cloud
Tualatin , Oregon
Images: 12
Send a message via Skype™ to smccollister
I would have started the original post with "So my friend has this problem..."
smccollister is offline   Reply With Quote
Old 02-15-2016, 09:50 AM   #25
Originally Posted by Zstreamer View Post
Made an embarrassing rookie mistake. Grey tank was almost full and dishes needed to be washed. I use a bowl to catch sink water and then I flush it down the toilet.
I have done this a few times. But when I empty my dishpan into the toilet, the toilet flush is CLOSED so that the toilet bowl fills. Then I flush. Anything that accidentally gets dumped never gets a chance to make it into the black tank because it's trapped in the toilet bowl where it can be fished out without needing arms like an anorexic orangutan. Fewer odors escaping that way, too.
WBCCI #1105
TAC LA-4
Old 02-15-2016, 10:44 AM   #26
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I ain't the smartest man in the world, but...
Looks like to me you just got a fork in your black tank...
It may be there forever-
It may come right out when you drain-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 02-15-2016, 11:03 AM   #27
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
This is not going to be helpful to the OP, but I gotta say that my best entertainment comes from reading posts on this Forum! I make it a point to learn from every post possible!
Larry
lsbrodsky is offline   Reply With Quote
Old 02-15-2016, 11:40 AM   #28
plumbers
If you really want to resolve this, you likely could find a plumber who has a fiber optic grabber tool, and (after a thorough drain/flush cycle or two), have them run this tool through the toilet into the tank. These tools have light and remote video, so even if the tank is not immediately below the toilet, they will be able to find and likely retrieve the fork. Unless the plumber is your uncle/aunt or nephew/niece, there will be a charge for it, but if you take the trailer to the plumber's place of business, maybe it would be relatively minor. Pretty easy and quick, compared to how those things usually get used. I would call around and see what prices get quoted, being clear on how short a distance it is going to be, and pointing out how this will simplify their tool cleanup work.
Likely there will be no issue on just leaving the fork in place, unless the fork catches some toilet paper and gets dragged into the valve seat during an 'empty'.
Best of luck.
dower.bill is offline   Reply With Quote
'74 Sovereign...object fell into blacktank torchflame Sinks, Showers & Toilets 12 08-18-2015 07:10 PM
EASY CHOCOLATE CAKE 1pan 1 fork 1 cup Airperson Stella's Kitchen 5 03-02-2010 09:18 PM
Electric Fridge or fork out the cash?? frscott Refrigerators 36 05-21-2009 08:49 PM
Metal fork in black water tank myboyburt Waste Systems, Tanks & Totes 23 04-29-2008 08:49 PM
My axles fell into place goransons Axles 0 03-19-2008 04:27 PM
