Old 08-15-2014, 09:56 PM   #1
Pacific Grove , California
Flushed the silver
At an RV park w/no sewer hookup so, trying to use black tank to keep from maxing out the grey water tank, I have been pouring the dishwater into the toilet. Just flushed a silver spoon. How can I retrieve it? Can I retrieve it? Will it come out in a flush? Shall I be ready with a colander? Yuck!
HRHCMHPG is offline   Reply With Quote
Old 08-15-2014, 10:22 PM   #2
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Check this thread.
http://www.airforums.com/forums/f163...nk-122456.html
Ken
Old 08-15-2014, 10:36 PM   #3
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Is it solid silver, silver plate or stainless steel? If solid silver or stainless a magnet won't work, but if it's silver plated it may. Test it on one of your other utensils. If it does, tie a strong magnet to a stick and probe around through the hole. If that doesn't work maybe one of those flexible push-button claw tools will. It's probably right below the hole now. If you open the drain valve, it may move it out of reach or lodge it against the drain hole creating more problems.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 08-19-2014, 01:08 AM   #4
It is still in the tank and won't flush out, so I will just leave it there until I can locate a magnet and am prepared to go fishing for it. No problems so far.
Old 08-19-2014, 05:36 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
After it's been where it's been, do you REALLY want it back?
Old 08-19-2014, 06:09 AM   #6
Tyvekcat's Avatar
2014 28' International
Blacksburg , Virginia
silver?
LOL I agree with Overlander, go buy a new set of utensils, I wouldn't want it back
Yard sale. Yeah I know you can use bleach, and run it through a dishwasher twenty times, I probably still would (Yard sale) LOL
Have a good one!
Ra, Chelle & Natasha
For my next trick, I will use my new Airstream & Dodge Ram 2500 CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Old 08-19-2014, 07:55 AM   #7
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Why don't you just pull the toilet and reach in and pull it out. That's why they make soap.
Have you ever shook hands with a plumber? Not much difference though you don't see too many plumbers biting their nails......
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is online now   Reply With Quote
Old 08-19-2014, 09:26 AM   #8
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have moved the trailer while it had fluid in it the spoon has most likely moved the the low end of the tank. If the toilet is mounted over that end of the tank removing it and fishing with a magnet or reach and grabber is an option.
If you have another of the same utensil look at the plumbing coming from the tank. take the utensil to a shop and see if you can bass it through a similar elbow. If it will not pass it can remain in the tank without causing great harm. If it can pass it could get stuck between the dump valve and the outflow. In that case you would have to cut the piping to get it out.
And yes I have done a bit of plumbing and I do not bit my nails.
2004 Excursion 4x4
1973 Silver Sovereign 31! AIRSTREAM. LOW RESERVE S1973 Silver Sovereign 31! AIRSTREAM eBay Watch Airstreams on eBay 0 09-22-2011 11:20 AM
Rare Silver Streak Motorhome, Like Airstream All Silver eBay Watch Airstreams on eBay 0 07-29-2011 06:04 PM
Silver Paint vs Clearcoating the Finish Jason1101 Clearcoat, Exterior Paint & Trim 50 09-02-2008 09:54 PM
The Saga of the Silver Belle - Conclusion winner Our Community 12 03-24-2003 08:59 PM
Silver Trim ALANSD Clearcoat, Exterior Paint & Trim 7 03-24-2003 10:17 AM
