Originally Posted by Sardog
I'm only trying to flush the hose before storage so how do y'all do it without using fresh water to do it?
You disconnect it from the black tank, and run water in one end while the other end is still down the opening at the dump station. Most dump stations have a water source, usually labeled "Non-potable," with a hose already attached. Often the hose will be lacking a male fitting on the free end, so that it's not even possible to connect it to your municipal inlet.
Don't forget to rinse the outside of the hose as well; and hose down the area around the dump station drain to wash any residue that ended up on the pavement instead of down the drain.
