Old 01-04-2003, 06:29 PM   #1
JLD
Send a message via AIM to JLD
Flush out connection
Hi. I have a 1978, 31 ft., center bath style, Soveriegn. I don't have a manual for it. Does anyone know if the vehicle has a flush out connection for the main holding tank. We have had problems with paper build up in the holding tank. Our solutions have been all the usual...ie a basket for peepee papers, extra potti chemicals since we are not traveling with it right now so don't have the advantage of road churning to break down waste, and a rule to add lots of water when doing the big stinky, but the problem persists. Recently a friend said he thought all trailers had a connection for the hose where the tank could be flushed, but I crawled underneath and didn't see anything. The chance I am looking in the wrong spot is very possible . Any advice?
JLD is offline   Reply With Quote
Old 01-04-2003, 06:54 PM   #2
If you don't have the black water tank flush, CW sells a device that you attach to a hose and stick it down your toilet to help flush it out.
If you can allow the black water tank to fill almost to the top prior to dumping, this volume of water really helps to displace the waste.
John
John is offline   Reply With Quote
Old 01-04-2003, 10:06 PM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
We had the same types of problems on our 77 center bath. I purchased a flush connection at CW that allows me to hook a hose to the sewer fitting and blast water into the drain pipe back towards the tank. It is clear so you can see the effect and what comes out. I would also use the dump hose as a flush tool.
First let me say DO NOT do this if you are using the slip on fittings without a hose clamp at the sewer fitting. You will have brown trout for sure if you try this with the slip on fittings.
Do an inital dump. Then hook up a non potable water hose to the flush fitting. Turn on the water. Once it flows, Lift the sewer hose up behind the fitting to a point that the water is no longer able to flow out. Once the drain line is full of clear water, drop the hose down to move water out but do not allow it to drain. Then lift it up quickly forcing the water back into the drain and holding tank. Do this 3-5 times. This will act as a sloshing to loosen the solids. Then you can allow the liquid and solids to drain. Do it again, (lather, rinse, repeat) and keep it up until when you dump all you get is clear.
The other option is to pull belly pan skin and install a tank flush system that you just hook the hose to. That is alot of work, and you have to dig in pretty deep to get it positioned correctly.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Valterra to Thetford connection Craig Waste Systems, Tanks & Totes 30 03-05-2011 08:49 PM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 04:25 PM
No Fuss Flush Leaks! dpope 2003 Safari 7 06-25-2005 03:48 PM
Tranny 'flush' or Filter change Sav'h Steve Mechanics Corner - Engines, Transmission & More... 18 04-02-2004 09:22 PM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 08:40 AM
