Old 01-16-2007, 05:08 PM   #1
geezernbabe's Avatar
1970 31' Sovereign
Rogue River , Oregon
Floor & Tanks going in the 31'
Well I have finely got the frame done. The grey and black tank are in and plumbed. So I was happy to put down 2 whole sheets of subfloor. It just felt good to get here. So next it's up with the rest of the floor and on we go. Will try for the pics, still having a little trouble seeing pics on this comp.
Name:	Lab _0000460.JPG
ID:	30915   Click image for larger version
Name:	Lab _0000461.JPG
Name:	Lab _0000462.JPG
ID:	30917   Click image for larger version
Name:	Lab _0000463.JPG
Name:	Lab _0000464.JPG
ID:	30919   Click image for larger version
Name:	Lab _0000465.JPG
Name:	Lab _0000466.JPG
geezernbabe is offline   Reply With Quote
Old 01-16-2007, 06:50 PM   #2
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Is this a center bath model?
What kind of wood is the floor?
I hope your removing the pink insulation.
'77 Sovereign Intl 31' CB
Old 01-17-2007, 02:58 PM   #3
1970 31' Sovereign
Hi Bob, this 1970 31' started out as a rear bath with no grey water tank. I am moving the bath to center and a rear big bed. The flooring is OSB tongue and groove. The pink insulation is going in the garbage a little each week. I took that as hint from somebody that has been there. Thanks Dave
Old 01-17-2007, 03:41 PM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Are U going to seal the OSB, you know what happens if it gets wet.
Old 01-17-2007, 05:11 PM   #5
Gold Rivet Member
tgregory13's Avatar
Fuquay , North Carolina
geezer,
can you give me some info on the tanks? how big are they? are oem or custom made? doesnt look like you moved any of the crossmembers is that correct?
Thanks in advance
have a good 1...
Todd
(why do i have to press 1 for english??)
tgregory13 is offline   Reply With Quote
Old 01-18-2007, 09:20 AM   #6
1970 31' Sovereign
When we built our house 18 years ago I used OSB for the roof sheeting.It took us a long time to build because we dit it all. One part of some temp roofing material blew off in the winter that I did not see. That sheet of OSB got rained on alot and all it did was swell up a little bit. So I sort of did a test without knowing. I have had plywood delam. more from getting wet. Any idea on what type of sealer would be good? Becaues I think it is a good idea.
The tanks I ordered from a web site that has about any size you would want. I have to run right now but if you want when I get time I will be glad to look in my notes and get the site for you they were great to deal with. Be back later.
Old 01-18-2007, 09:26 AM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Depends on the grade of OSB. But the sealer is still a good idea.
Aaron
WBCCI #XXXX AIR #2495
Old 01-18-2007, 05:42 PM   #8
Gold Rivet Member
tgregory13's Avatar
when you get time i would like to know where you bought them from and the demisions...
have a good 1...
Todd
Old 01-19-2007, 10:16 AM   #9
1970 31' Sovereign
I found the notes. The site is plasticmart.com, Ph 866-310-2556. The guy I talked to in the shop is named Tank. The black is # el263h and the grey is rv69w. If you go to the site it is real easy to pick from a huge list of tanks. They both fit between the cross members. The black tank is sitting in rubber covered angle iron bolted from frame rail to rail. The grey is just a flat water tank that is sitting on an aluminum floor I built in that bay behind the rear axel. They will send you a drawing of the tank and put any fitting or opening anywhere you want it or they can build one anyway you want. I posted a few pics in another thread in this section.
Old 01-19-2007, 10:54 AM   #10
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
That's too funny.
Fyrzowt is offline   Reply With Quote
Old 10-04-2007, 03:09 PM   #11
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Here is a link with the correct address
Custom Plastic Tanks Marine Water Holding RV - Plastic-Mart
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
LP Tanks Craig LP Gas, Piping, Tanks & Regulators 6 08-22-2002 08:43 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
