Old 08-14-2006, 09:12 AM   #1
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
FloJet Waste Pump
Bought this pump so I could back flush my tank at home. Very pleased with the results. It pumped a VERY strong stream of water through 75' of 3/4" hose across level ground to my home's sewer cleanout access. Easy to use, just hook up the water hose and the drain hose, turn the flush valve on and let it do its work. Turn the flush valve off and turn on the pump. The results were pretty nasty.
Hooked it up to a dedicated 12 volt circuit, with a weatherproof outlet installed inside the fridge access door. I used a 20 amp, 110 volt plug and receptacle instead of the usual 12 volt connections. Everything is clearly marked as being 12 volts in case I go brain dead . Looks and performs like a quality product but it is a bit pricey.
Greg
Roadtoaster is offline   Reply With Quote
Water Pump cycles often Guitars Water Heaters, Filters & Pumps 3 11-19-2002 07:04 PM
Water Pump Joan D'Andrea Water Heaters, Filters & Pumps 3 11-01-2002 06:31 AM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 09:13 PM
Water pump has quit roessler Water Heaters, Filters & Pumps 8 08-14-2002 03:02 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
