Old 09-01-2015, 11:05 AM   #1
1961 24' Tradewind
1967 26' Overlander
Savannah , Georgia
Flange removal from 67 Overlander
So need to replace the rear couple feet of flooring under the bathroom of my 67 Overlander. I have the fixtures removed for refinishing. However, the PO put some sort of iron sheet metal under the toilet and under the flange. This was obviously some sort of a fix for soft floor as it was installed over the original layer of tile. I am trying to figure out how to remove the toilet flange without damaging the black tank. The screws holding the flange to the subfloor are rusted but still solid and I cannot remove them.
Suggestions?
beatrix1 is offline   Reply With Quote
Old 09-01-2015, 03:57 PM   #2
1979 23' Safari
Wayland , New York
Try a wrench grabbing the screw heads or hacksaw blade, just the blade slid under the flange to cut the screws. The screws need to come out.
Use stainless screws when you put it back together.
Old 09-05-2015, 10:29 AM   #3
1961 24' Tradewind
1967 26' Overlander
Savannah , Georgia
Finally got it off. Used a Dremel with cutting blade to cut the screws then a hammer to drive it counterclockwise (slowly) and unscrew the flange. Now the fun begins to drop it from the bottom. Ugh.
Toilet Flange Removal trouble nikiarntz113 Waste Systems, Tanks & Totes 13 01-22-2016 10:29 PM
AC removal before interior wall/shell removal? TexasAir67 Exterior Restoration Forum 1 07-25-2013 07:58 AM
Toulet flange removal..avion Becky B. Sinks, Showers & Toilets 3 04-21-2013 03:15 PM
Black Tank-To Flange or not to Flange? Mrwaterway Waste Systems, Tanks & Totes 4 12-02-2009 09:02 AM
Cabinet Removal - Closet Removal 2333 Cabinets, Counter Tops & Furnishings 2 10-05-2006 01:00 PM
