Old 06-13-2017, 03:04 PM   #1
1968 26' Overlander
Ghent , West Virginia
Flange on black tank
I'm new to this I have a 1968 international land yacht it has a thetford valve on the black tank need the rubber gasket goes against the flange on the tank can't find it any where local camper stores telling me to take the flange out of the tank and replace with all new stuff I don't want to damage anything can the flange come out of the tank
Yacht68 is offline   Reply With Quote
Old 06-13-2017, 03:27 PM   #2
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
If it's like my 67 was the valve is screwed (4 screws) to a mount that is molded in the tank.
The screws on mine were very rusted & I'm not sure they would come out without cracking something.
In the picture the 2 (of 4) rusty upper screws are what mount the valve to the tank. The two shiny ones mount the fitting to the valve. Good with your project. Click image for larger version
Dingo Girl is offline   Reply With Quote
Old 06-13-2017, 04:17 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I had to replace both the valve and tank on my 68.
Inland RV should have what you need.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 06-13-2017, 06:19 PM   #4
1968 26' Overlander
Thanks I thought that it maybe I'm think I may get a new gasket if I can and put it back on to my knowledge this tank has never been used
Old 06-14-2017, 12:11 PM   #5
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
On my 72' the 4 screw flange looks like it is threaded into the black tank. You could then change everything to valterra type. Or a new thetford valve will come with a fresh gasket
bibbs is offline   Reply With Quote
Old 06-14-2017, 01:55 PM   #6
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
If it's leaking...
Sometimes it's not the gasket, it's a tiny crack where the tank-flange mounts. Is your black tank polyethylene (Thetford) or is it ABS(unknown manufacturer)?? Cracks in polyethylene are best welded. Cracks in ABS are best epoxied.
Gaskets come with a new Thetford valve.
!968 was an early, somewhat experimental black tank era. For a 30 foot trailer, It would be reasonable to reconfigure the waste system with modern grey and black tanks using Valterra valves.
If time and $$ aren't easy right now, the link below has possibilities...
http://www.airforums.com/forums/f48/...re-159949.html
ALUMINUMINUM is offline   Reply With Quote
black tank and toilet flange; when is it necessary to replace the tank? Globie64 Waste Systems, Tanks & Totes 7 09-07-2011 04:04 PM
Glue or clamp flange to black tank? pilgrim_still Waste Systems, Tanks & Totes 12 03-11-2010 07:08 PM
Black Tank-To Flange or not to Flange? Mrwaterway Waste Systems, Tanks & Totes 4 12-02-2009 09:02 AM
Black tank square flange adapter SummitAir Waste Systems, Tanks & Totes 4 09-09-2008 04:27 PM
Replacing 1963 Safari black water tank flange?? 63 Safari MT Waste Systems, Tanks & Totes 0 05-30-2008 07:51 AM
