Old 04-12-2011, 12:12 PM   #1
j Z
1979 23' Safari
Great Falls , Montana
Fix or replace this tank?
Attached is a picture of my 1979 Safari gray water tank. I found it partially detached and dented inward. Is there any way to repair this tank? One of the spin-on fittings has come undone as well. I am thinking that a new tank would be the easiest fix.
Cheers,
j z
j Z is offline   Reply With Quote
Old 04-12-2011, 01:19 PM   #2
Cheers,
j z
That tank is still available.
Old 04-13-2011, 07:14 AM   #3
j Z
1979 23' Safari
Cool, Andy. What does a new tank go for?
I was looking at some other tanks that offer a larger capacity. What was the capacity on my old one?
Also, my black tank has a cracked outlet lip where it attaches to the 3" ABS pipe. It appears that the outlet was undersized and the ABS was forced into it at manufacture. Over time the tank yielded and cracked. Right now, I have a rubber boot connecting the black tank to the waste valve. Hope it holds for a while.
Old 04-13-2011, 08:32 AM   #4
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Cheers,
j z
I had one of my fittings on my black tank detach. They tried to fix it and the fix failed. Replace the tank.
Do a little shopping and you can save some money.
Michelle TAC MT-0
Sarah, Snowball
Old 04-13-2011, 08:54 AM   #5
j Z
1979 23' Safari
Spend a little money or clean up a mess in the campground? I'll just get the new tanks...
gray water tank, safari
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
'69 Globetrotter, Black tank for streetside bath dieselpup Waste Systems, Tanks & Totes 9 03-03-2011 06:50 AM
New Slant on Tank Sensor Cleaning... Mexray Waste Systems, Tanks & Totes 5 01-30-2011 01:07 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
