Old 04-19-2016, 04:00 PM   #1
1978 31' Sovereign
Botgek , Washington
Fix cracked tank? help
Is this worth trying to salvage? I live in the Seattle area and I can't find anyone who does plastic welding. I've read a couple post about the harbor freight plastic welder but that is last resort. A new tank is 495 and I would prefer not toss this one if I can salvage it.
Ryan
Name:	cracked gray tank.png
Sirwalshalot is offline   Reply With Quote
Old 04-19-2016, 05:25 PM   #2
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
I may be wrong,so don't quote me on this.... But, I believe one cannot weld the tanks due to the type of plastic they are made from. Seeing the cost, hopefully I am wrong....
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
truxpin is offline   Reply With Quote
Old 04-19-2016, 06:48 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I think that tank is repairable.
It could be a DIY project, depending on your skills.
Plastic welding kits are available.
Google search will turn up some interesting video.
Old 04-19-2016, 06:52 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Contact URETHANE SUPPLY. They are the masters of plastic repair and have the tolls to help you perform the repair, along with the required techniques.
Old 04-19-2016, 06:55 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Since you can get at the tank I think the Harbor Freight plastic welder should be your first and best fix. If you have it out, remember it is a 40 year old tank. I had a similar split (from overfilling) last year and tried a spray on product like Flex-Seal. We will see if it holds up to TV commercial standards. I had to cut out a window in the plywood tank support to get at it. If that doesn't work I will have to drop the tank. If I have to go through the work of dropping the tank I may go with a new tank rather than a repair.
Old 04-19-2016, 06:56 PM   #6
JimGolden's Avatar
1977 31' Excella 500
3m
That looks like a pretty big crack. But, let me give you, just maybe, some good news:
3M makes a glue that will glue polyethylene. You won't see it at Home Depot or Lowes. You will need to find a 3M Sales Rep. It comes with this nifty neato squeeze tube that meters out the resin and the hardener in the exact ratio at the same time (a double barrel squeeze tube with different sized barrels).
The fresh water tank in my 34' had a crack in the top of the tank about an inch long. I got some white polyethylene sheet, about 1/4" thick, and cut a 3" by 3" square. I then roughened up the top of the tank where the crack was with sandpaper, and did the same to the 3x3 square, then glued them together with the 3M miracle glue. Ten years and 25,000 miles later, no problems of any kind.
I don't forget the ID number of it as it's been so long. You can probably Google it and find out. But, 3M does make a glue that will glue this tank.
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
Old 04-20-2016, 07:40 AM   #7
1978 31' Sovereign
Botgek , Washington
Thanks all for your response.
I will contact urethane supply and update the forum with what I choose to do.
Ryan
Old 04-20-2016, 08:32 AM   #8
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Also - shop around for a replacement tank. That $495 sounds like it's coming from the factory. Truth? The factory contracts out for tanks - doesn't make them. So, do some Google searching IN and outside of the Forums. I've been reading here for a long time, and more than once someone found a custom tank maker who'd to a whole new tank for a fraction of the amount quoted by the dealer or factory.
Regarding patching - I too drank from the garden hose as a child - and rode a bike without a helmet - and never heard of a child safety seat until I was a teenager, so I tend to not be fanatical about using germacidal soap, etc. You're repairing a gray tank, so your only concern is that it not develop a sneaky leak any time soon. If anyone reads this thread and has a problem with the water supply (white) tank, take care with any sealant you use to make sure it's safe to use on a tank that holds drinking water.
Paula
Old 04-20-2016, 10:08 AM   #9
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Check with Inca Plastics for a quote on the tank. They were the supplier of many of the tanks used in the 70's trailers, and they can probably make you one up exactly like what you have.
As for repairing that tank, I would guess it is a lost cause. I have one of the HF plastic welding kits and have played with it extensively. My conclusion is that it is extremely difficult, and technique sensitive to get a weld that is as strong as, say, a rotomolded corner. Your tank cracked because it is 40 years old. Even if you manage to repair that crack, it is pretty likely that it is ready to crack someplace else.
good luck
Old 04-20-2016, 10:11 AM   #10
Ryan
Ryan.
Yes, a replacement tank is not cheap, but neither is anything else for your 1973 Airstream.
That tank crack, because it's old. Repairing it is some what foolish in that it will continue to crack. When that happens, you then will go through the same issues as your having today.
When will another crack show up ? Most likely on a trip. Then, more problems will be added along with the tank problem. Welding old plastic tanks does not cure the fact that the tank is simply aged out, and will continue to crack. Best long term correction, is to replace the tank. Why ?? You then can kick the tank issue to the curb, and perhaps find something else to worry about.
Again, it's a large sum to correct, but so is, as another example, replacing the axles. But most owners are aware that torsion axles only last about 25 years, or even much less if the trailer was parked and not moved for a couple of years or more.
Owning an Airstream, in time, does cost money to keep it going, but most owners understand that when they purchased it. Maybe not in labor, but certainly with parts.
Old 04-20-2016, 12:31 PM   #11
e5earley's Avatar
1969 31' Sovereign
Paris , Texas
I would attempt to fix it first. Other than your time and effort to install you have nothing to lose. I wouldn't invest in the harbor freight welder. The best I have found is a soldering iron used for stained glass.
I have welded quite a bit of plastic. Mostly atv fenders. Try to find an area of the tank where you can shave some plastic off. It will make the best filler material. The filler rods that come with the welding kits may be incompatible with the tank plastic. I would drill a small hole at end of crack to stop it from cracking further. Then use your iron to tack weld the crack every few inches. Then form a v in the crack with your iron. Now you can start using your filler material to weld the crack, pushing the plastic in from the sides of the v. Now you can check for leaks and fix any problem areas. The final step is where you'll get your strength. Take a piece of aluminum window screen cut larger than the crack area and using your iron, embed it into the plastic.
e5earley is offline   Reply With Quote
Old 04-20-2016, 01:19 PM   #12
1967 26' Overlander
Spartanburg , South Carolina
Many auto body shops now do plastic welding because so many cars have plastic fenders and bumpers.
Jacob D is offline   Reply With Quote
Old 04-20-2016, 02:31 PM   #13
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
good luck
I appreciate the information on Inca Plastics. That's a good source!
http://www.incaplastics.com/page15.html
Old 04-20-2016, 07:21 PM   #14
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I believe snap -on sells a plastic welding outfit, the harbor freight one is also good....
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
Cracked Black Water Tank Invert Repair toga Waste Systems, Tanks & Totes 5 03-25-2009 08:35 AM
Black Tank Cracked....HELP rlindberg Waste Systems, Tanks & Totes 10 03-21-2009 06:19 PM
water heater tank cracked. JB weld? Curtis-79MH Classic Motorhomes 12 06-09-2007 04:07 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
