Old 12-02-2015, 07:35 PM   #1
1973 31' Sovereign
Sumiton , Alabama
Fittings in ABS tank
Moving forward on my 1973 land yacht and final order tanks today a gray and black. The tanks are abs plastic and has the 3" dump fittings and probes but I will need to add the toilet and vent as well as a vent and inlet for the gray. Any suggestions on how to glue the fittings to the tanks? I've not been able to find a rv shop that spin fits as yet but thought I read a forum here about using a glue but not been able to get back to it. Suggestions please?
mingle51 is offline   Reply With Quote
Old 02-16-2016, 09:35 PM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Use abs cement glue- works great. Or they also make rubber grommets
Matt
rugjenkins is offline   Reply With Quote
Copper compression fittings vs. flare fittings phippsto LP Gas, Piping, Tanks & Regulators 37 12-07-2015 03:08 PM
Plumbers, Help ! PVC fittings with ABS pipes alumascoupe Plumbing - Systems & Fixtures 18 08-25-2013 04:48 PM
How do you glue ABS fitting to ABS tank? Mike&Ali Waste Systems, Tanks & Totes 9 12-09-2010 07:19 PM
Sealant for holding tank & dump fittings? wayner1239 Waste Systems, Tanks & Totes 8 04-06-2006 06:58 PM
