Old 01-17-2011, 10:19 PM   #1
new braunfels , Texas
Extra 67 tradewind blackwater tank, gray water tank
I have a 67 tradewind I am converting to a commercial kitchen. I have removed the subfloor and pulled out the blackwater tank. The tank is not cracked and holds water, but the flange connecting to the effluent pipe running outside pulled away from the fiberglass. It can be fixed with a new flange and applying more fiberglass if you are handy.
I am willing to part with this and the gray water tank which is also in good condition. I would rather trade for parts than sell it-- I need:
Custom Bargman Door Handle (the long one),
A matching rim (wheel) with clips
Window hardware
Jack crank handle or working jack motor
I am in New Braunfels, TX, but travel frequently around Texas-- I can also ship--
poezlaw is offline   Reply With Quote
Old Water Tank Removal & Clean up IronGiant Fresh Water Systems 9 06-23-2011 08:53 AM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 07:00 PM
replacing black water tank in 68 Tradewind clydecrashcu Waste Systems, Tanks & Totes 1 01-17-2011 10:28 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 08:01 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 06:42 PM
