Old 06-03-2014, 06:32 PM   #1
1962 24' Tradewind
Huntington Beach , California
Elbow Joint From Sewage To Drain Hose on '62 Tradewind
I don't know what it's called but, I need a new one and the guy at the parts desk was not helpful.
It's the piece that comes out of the RV (elbow or J shaped) that you hook your sewage up to. It was damaged from scrapping and can not be connected to the hose.
Any ideas on where to get a replacement part, would be greatly appreciated.
~Obviously, I'm totally new to RV's in general but, especially my old one.~
ABomb1 is offline   Reply With Quote
Old 06-03-2014, 08:18 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
There is a good chance that the elbow is not original. If you post a photo we can tell.
Typically these are either cemented in place or, less often, bolted to a valve.
You could also look through the photos here and see if you can find what you need. I don't necessarily endorse, buy them wherever you want.
Holding Tanks,Fittings, Vents on Sale! - Adventure RV
Old 06-04-2014, 12:33 AM   #3
1962 24' Tradewind
There is a lot of silicone around the end of the fitting, as a temporary fix.
Sewage drain valves leak shackman Waste Systems, Tanks & Totes 1 06-14-2013 01:28 PM
sewage dump hose oldiesel All Argosy Trailers 4 06-29-2012 03:35 PM
Black water sewage hose Muddy Waters Waste Systems, Tanks & Totes 21 06-12-2008 08:56 PM
sewage hose str8strm Classic Motorhomes 7 05-22-2005 08:26 AM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
