Originally Posted by dawncquinn
water from the black tank flows out whether the valve is open or closed, and water from the grey tank is stuck in there--it doesn't come out even when the valve is open.
Should I just suck it up and replace the valves? If so, is there an easy.. no, i mean, a less hard way to access those valves? Any and all ideas are welcome!
Dawn
Dawn
Here is a link where I wrote a "
How-to" on getting to those valves. I think that your set up is differant but you will get the idea.
Here is a How-to on getting to those valves.
As far as repairing your valve with a
repair kit, forget it. The two plastic tits that are on the gate valves are broken.
Click here to look at the repair kit
Once you get to your valves you will be able to see which valve you will need.
Press to fit Valve
Bond on Valve
Dawn
A side note here, your valves had not moved for a while. The same amount of work would have gone into taking it all apart, and the plastic that broke was needing to be replaced.
Dan
