Old 05-27-2019, 03:36 PM   #1
Levelland , Texas
Dump valve replacement
I have a 2014 International 27 ft Airstream. How do I change dump on black and gray, the trailer is sealed on bottom.
Troy Tyson is offline   Reply With Quote
Old 05-27-2019, 03:54 PM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Drop the bolted section down
Old 05-27-2019, 03:59 PM   #3
Levelland , Texas
it is sealed up with pop rivets
Old 05-27-2019, 05:30 PM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Drill out the pop rivets. Drop the belly pan. Create an access panel after doing the repairs.
Use SEARCH there are one or two great threads om replacing dump valves without taking a s----- shower.
Old 05-27-2019, 05:38 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
This thread shows how I changed them on my 1999 Excella. Toward the end of the thread there is a post on a 2009 Classic.
Yours should be similar.
http://www.airforums.com/forums/f444...es-162941.html
Why do you think the valves need replacing? On a 2014 trailer the valves should be good for several more years. Mine were 20 years old.
ps:
When you get into it, would you please add photos and a description of your experience so that others can benefit from it? Adding to the thread I started is OK with me.
Thanks!!!!
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 05-27-2019, 05:41 PM   #6
Go to Restoration Forum, then choose Plumbing subforum, then browse through several good threads.
Old 05-27-2019, 07:15 PM   #7
CRH
1995 25' Excella
xxxxx , xxxxxx
My owners manual says to service the dump valves "they" cut an access hole in the belly pan, make the repairs, and install a cover plate. That is exactly what I did when I replaced my valves....The trailers should come with an access panel from the factory, IMO.
CRH is offline   Reply With Quote
Old 05-27-2019, 08:33 PM   #8
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Me too with cutting an aces hole. That is what Airstream did and what I did on the second trailer. Much easier than dropping the pan. Also wondering what tha actual problem is with the valves? I know from experience that the valve body can crack and that the seals can tear. But also stuff that can be cleaned out can get caught in the valve. It is an expensive job to have done.
Thetford Dump Valve Replacement in my 71 Lumatic Waste Systems, Tanks & Totes 14 11-26-2016 10:06 AM
'65 Caravel dump valve replacement kevinkatz Waste Systems, Tanks & Totes 8 12-24-2014 01:53 PM
1971 - can't find dump valve replacement Betty3117 Waste Systems, Tanks & Totes 2 08-02-2010 07:41 AM
67' Caravel Dump Valve Replacement 18706 1967-Caravel Waste Systems, Tanks & Totes 17 04-11-2009 11:14 PM
Need help for Dump valve replacement . kooshka Waste Systems, Tanks & Totes 6 09-08-2008 07:21 PM
