Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 10-11-2002, 03:07 PM   #1
Profile:
Dump Valve Rebuild
I just rebuilt the original cast brass dump valve on my 1961 Safari. It was either rebuild it or replace it. I managed to rebuild it with new 'O' rings from Sears and some custom parts. A brief rebuild description is posted below.
(there are some pictures of the benched valve in my photo album)
wagsrp is offline   Reply With Quote
Old 10-11-2002, 03:21 PM   #2
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Always provide the juicy details. The members of this Forum family can't get enough details about these trailers. Its like gossiping about the co-workers.
By sharing, even the people who have never done a rebuild can tell you how you did it all wrong.
Share your discoveries for the present and future visitors. Try to include pictures.
Best Regards;
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 10-12-2002, 02:01 PM   #3
Profile:
Rebuild Details
The rebuilding process required a) replacing all the O rings (Sears had them) b)cutting a new upper-case rectangular gasket from sheet gasket material from a local plumbing supply c)smoothing the surfaces of the knife blade d)designing a spacer plate to raise the knife blade; from use and smoothing the knife blade had reduced in thickness to the point that it would not seal against the O ring e) adjusting the thickness of the rectangular gasket (using a palm sander) between the two valve assembly halves such that the valve assembly halves could be bolted together with enough pressure to a)produce a leak-proof valve shutoff and b)seal the two valve assembly halves.
The valve is back in and currently works very well. For how long who knows.
(there are some pictures of the benched valve in my photo album )
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 03:37 PM
Dump Valve Sneakinup Waste Systems, Tanks & Totes 27 05-23-2005 03:31 PM
Dump Valve Leak David Hall Waste Systems, Tanks & Totes 8 02-17-2004 06:26 PM
Repacing blackwater dump valve Rick Alston Waste Systems, Tanks & Totes 3 02-03-2004 04:20 PM
63 Safari Dump Valve Questions srgntpepper Waste Systems, Tanks & Totes 1 09-10-2003 07:40 PM
