Old 01-18-2010, 10:43 AM   #1
Maniacal Engineer
barts's Avatar
Menlo Park , California
dump valve location
Where is the dump valve on a '72 Tradewind? There's a picture in the
manual, but not enough of one for me to find it .
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 01-18-2010, 10:55 AM   #2
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Look under the trailer and it should be rather evident.
SilverHoot is offline   Reply With Quote
Old 01-18-2010, 11:10 AM   #3
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Don't know about the Tradewind but on mine it is on the left side in the rear bumper.
It has to be close to where you hook up your sewer hose.
Garry
Old 01-18-2010, 11:11 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Look inside the rear bumper compartment.
Richard
Old 01-19-2010, 01:17 AM   #5
Maniacal Engineer
barts's Avatar
The only thing at the left rear where the dump outlet is is an aluminum tube that might be a push pull sort of valve actuator, perhaps? It doesn't respond to either pushing or pulling, however; perhaps it's stuck...
- Bart
Bart Smaalders
Menlo Park, CA
Old 01-19-2010, 08:07 AM   #6
SilverHoot's Avatar
1967 24' Tradewind
Bart,
That's probably it. Any chance you could take some pics? Somebody here would almost certainly be able to help with pics.
Old 01-19-2010, 08:09 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
- Bart
That's it, and it's probably stuck. Add some water to the tank, and let it sit a while, and try again. Umm, stand away from the outlet, in case the previous owner left you a present.
Old 01-19-2010, 08:19 AM   #8
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
On my 1967 Tradewind the dump valve outlet is on the left inside the rear bumper compartment. There is a small trapdoor under the outlet for the hose.To open the valve you have to remove the back electrical cover above the bumper cover to pull the valve handle. My handle has two wire bails that hold the valve in the closed position. Adios, John
Diesel1 is offline   Reply With Quote
Old 01-19-2010, 08:21 AM   #9
Maniacal Engineer
barts's Avatar
Thanks! I'll give that a try, and use a bucket just in case....
- Bart
Bart Smaalders
Menlo Park, CA
Waste dump hose storage location bkahler Classic Motorhomes 7 09-28-2007 06:38 PM
dump valve (once again) eubank Waste Systems, Tanks & Totes 13 09-08-2007 10:56 AM
Dump Valve Sneakinup Waste Systems, Tanks & Totes 27 05-23-2005 02:31 PM
Dump valve ALANSD Waste Systems, Tanks & Totes 4 12-04-2002 06:07 PM
Dump valve gwsullivan Waste Systems, Tanks & Totes 11 05-30-2002 08:38 AM
